How do you downgrade from 3.0 to 2.9? Doesn’t seem to work the same way as upgrading.
Transfer the ROS 2.9 files to the Router then issue the command “/sys package downgrade”
Be sure that you are connecting from the lan interface when you do it. In certain cases (dunno if in all), the wireless interface will have to be reconfigured from scratch.
Downgrade from 3.x to 2.x from remote is not advisable, unless you’ve access to the lan port from remote.
/Martin
