i am trying to downgrade from ros 6.34.3 but which ever version i choose it tells me omitting package routeros-tile 6.34.2: min routeros version 6.34.3
the current version loaded on the ccr is 6.34.3
has anyone come across this issue, and how do i downgrade
I think you will not be able to downgrade it below the version that it came with.
When my CCR arrived a month or two agoI UPgraded it to 6.35.2 and actually support for some of the hardware was better.
So I would not recommend downgrading it.
Then why not try upgrading it instead of downgrading?
Also /export the config and diff it.
Finally, RADIUS servers often restrict the source addresses, maybe the new CCR has to be added.
