Downgrade Question
If I have beta7 on a RB112 or RB533c if I want to downgrade to earlier beta (say Beta6) or to a 2.9.41 can I just copy the single upgrade package to the routerboard and do a system restart just like how I upgraded them i the first place or does it need to be done a different way?
Thanks - never had to downgrade before but I want to know how if I need to.
Scott
Copy the file in, go to system/packages and select ‘Downgrade’
Regards
/Henrik
FYI, your wireless interface will be disabled after the downgrade, learned that the hard way.
Okay; seriously, you guys: why are you rolling out BETA code in a production environment?! :slight_smile:
– Nathan
My opinion is the best and pretty much only way to get real world results is by testing in a real world environment.
I’m sure all this stuff works great in the lab, but 300ft on a tower in the middle of the city you find out what it is really made of…
Scott
