So I have the following problem: I upgraded RouterOS at a small hotspot WDS network (1 main Groove, 2 slave grooves) we have 200KM away, I guess I got too complacent with all previous OS updates working fine but it seems 6.33 broke something on our “check in and download a script and run it if necessary” system. Everything else worked 100% fine so I didn’t pick it up.
Now I can create a VPN the main router and I downgraded it to 6.32.3 and now the check-in system runs fine but how can I downgrade the 2 slaves? Those 2 can’t pick up our “connect to VPN” script because of obvious reasons.
My colleague managed to downgrade them through telnet, but I just tried it for kicks and it works brilliantly. Will make my life easier in the future. Thanks!
Glad it was useful, you can even save RoMON accessed devices directly on WinBox, it will remember the “agent” and store both passwords (agent’s and accessed device) on Winbox…
You can also use ping and ssh over RoMON (/tool romon). And even Drag and drop files from one winbox instance to another.
RoMON will also work over multiple hops independently from Layer2 / Layer3, as long as all the devices have RoMON enabled.
