Sorry i can’t help you how to downgrade firmware, but i think if you answer following questions we are close to solve the problem “root”
1, in the measurement of speed you are use 450G 100Mbit and the uplink connection 1Gbit?
2, you are use 450G port in switch mode?
3, speed changed both directions or just download, and upload is fine?
@willy:
100 Mb down/up
yes
both directions
Please do not make post if you are not sure about understand the question.
Poster query about how to downgrade the firmware you are answer how to downgrade the OS.
Ok. Maybe I did not understand the question but I know that npk packets refer to RouterOS (witch is 4.17 to me and worked very well until firmware upgrade to 2.29) not to the firmware itself. Maybe I’m wrong. I am really sorry.
Never did a firmware downgrade on a RouterBOARD so these steps may not work at all. My first though would be backing ROS configuration up, downgrading ROS to a version that comes with firmware 2.28 (a not so old ROS 4.x should do the trick), downgrade the firmware (Will “/system routerboard upgrade” allow downgrading firmware? I am not sure if a downgrade is possible or even advisable), upgrade ROS again to 4.17 and recover configuration from back up.
On this page there is an “ar7100-2.27.fwf” firmware that looks promising. I am not sure how can this one be applied (perhaps with “/system routerboard upgrade”? rebooting?)
However, I am running 2.29 (in both ROS 4.17 and 5.1) and have seen no problems that I would say are related with RouterBOARD firmware itself. Perhaps MikroTik staff will be interested in a support file from your router.
That is the answer to my question. The problem was with the firmware 2.29. Now I downgraded to 2.27 and it works very well. I suggest other users to stay away with 2.29
@willy
Thank you very much for your effort and suggestions.
Thanks for an explanation, but if possible i have some questions for you:
I have long standing problem and seems to similar of your problem, but i need to know. If possible please write me the port speed i think you connect with 1Gbit to internet and 100mbit with 450g.
Also please give advice to users, how to downgrade the board firmware.
I am glad to know that a firmware downgrade is a valid workaround to your problem. Did you have a chance to get a support output file for MikroTik technical staff before downgrading firmware? If you had a chance to get one, perhaps a second supout.rif file (this one from a working configuration with firmware 2.27) will help them understanding what is broken with 2.29 on your set up and fix this problem on a future firmware release.
Thanks a lot for sharing with us the downgrade results.
I use ether1 (WAN1) and ether 2 (WAN2) with 100Mb for internet and ether5 with 1Gb both with auto-negotiation. (I have two ISPs). Of course wih load-balancing and failover routines.
Last operations:
from terminal window:
/system routerboard print
and check the “update-firmware” to see if the downgrade version was “seen”. If it is then you will put:
which, in this case will do a “downgrade” firmware.
These are the steps I followed to downgrade the firmware to “original”.
I hope you will be satisfied with the answers.
If you need more help don’t hesitate
Thanks! Good documentation point to users. I also figured out this over ftp/ssh and works. This will be very useful if
any firmware upgrade make headache and want to back to earlier.
But big warning: Do not downgrade the firmware to lower than the device released! Be careful! Downgrade only if you exactly know what will happen (for example device runs with this version before).
Thanks also the port speeds, i will try testing with fw2.27.
