hi
i want to downgrade my router from v5 to 4.16. ![]()
how can do it?
thks
You need to use the netinstall to downgrade
Is it the only officially supported way to downgrade, or is it at least the safest?
Because I used to downgrade through “/system packages downgrade”.
You should be able to downgrade with “/system package downgrade” as usual
