Downgrade?
is there any known issue with downgrading?
Thank you!
No, but for kind of fail save backup config to local pc.
Thank you!
Is the routeros-tile-6.3.npk enough?
I just upload and restart, right?
I assume you have a CCR? I ask because you have a “tile” package.
To downgrade, you will need to go to system → packages and select “downgrade” after you have uploaded the npk file
Yes, thank you!
The downgrade was successful.
