Downgrade.
I have a router with latest firmware 6.28.
I want to downgrade to previous 6.27
Not sure about the procedure, not sure where I can download previous version 6.27 and not sure if i will lose the configuration.
Any advice ?
Thanks in advance.
For downloading any firmware, copy link for current one and just change version number in the link by yourself.
You shouldn’t lose any configuration, but, of course, it’s better to do backup and an export of configuration.
Download the file as per G2Dolphin instructions, drag it to a Winbox > File window, then go to System > Packages and click the downgrade button.
Done !!! Thank you G2Dolphin and pukkita
