Download in RouterOS
Is there command work as wget in MikroTik RouterOS v3?
http://wiki.mikrotik.com/wiki/Fetch
It is a little confusion for me to compare fetch to wget. Can you give an example if I want to download this file into MikroTik? http://66.228.113.58/mikrotik-4.2.iso
/fetch mode=http address=66.228.113.58 src-path=mikrotik-4.2.iso dst-path=mikrotik-4.2.iso
Is this tool available for v2.9?
No. Also, 2.9 is no longer supported. Upgrade
So I can not download anything using any method in v2.9. can’t I?
As far as I know, you cannot. Mikrotik said that everyone with a valid license can upgrade to 4.x, so there’s no reason not to.
Yes. I will try that. Thank for you support.
