Hello everyone,
I am using Mikrotik RB3011 , And My internet connection comes from my isp modem(bridge mod) to mikrotik router.
I have set up the mikrotik with quick set up mode without default config. And i am able to connect internet with lan port.
But, speedof.me gives error, speedtest.net does not work properly. Also during downloading process speed goes climax first and then goes down to nearly 0 mbps (this cycle repeats during downloading)
This problem does not occur while i connect the my main modem with a router mode
Any idea what is behind the problem ?
Speedof.me ss
http://imgur.com/a/XtKbJ
Steam downloading ss
http://imgur.com/a/S6U06
# may/21/2017 19:55:37 by RouterOS 6.37.5
# software id = D30F-EWV3
add name=bridge1
add name=dhcp ranges=192.168.5.10-192.168.5.254
add address-pool=dhcp disabled=no interface=bridge1 name=dhcp1
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=ether10
add bridge=bridge1 interface=sfp1
add address=192.168.5.1/24 interface=ether2 network=192.168.5.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.5.0/24 gateway=192.168.5.1 netmask=24
/system clock
set time-zone-name=Europe/Istanbul
/tool bandwidth-server
set max-sessions=10
