hi,
what are the max speeds on upload and download that those 2 routers (on the above subject) can be supported.
I would like to know what max speed i can get from my ISP.
thanks
hi,
thanks
one of them has Gigabit ports, the other doesn’t. Therefore there is a very big difference in potential speed ![]()
That i know, but i mean the speed of the my ISP. they offered me 10Mbs/3Mbs. are those 2 models can support 3Mbs upload?
It is one and the same. RB750GL supports up to 998Mbit/s throughput actual speed (or as you say ISP speed), depending on configuration. Tests are here;
http://routerboard.com/RB750GL
(bottom of page)
