I have MikroTik CHR OS x64 with the latest version connected with 10 Interfaces, 1x Out to firewall and 9x In routers. So, If I’m trying to download a file from IDM working fine with the full bandwidth from the 9x routers BUT with any other application for ex. google chrome, working only from ONE INTERFACE not all of them as IDM.
IDM is still just a downloader - it may just chunk it out and try get multiple streams going - which can help depending on features of your firewall or ISP in what they might do for rate limiting (PCQ etc)
A lot of variables at play here, and you’d need to isolate down to which device/port/portion is causing the issue.
Thanks guys for your replies. So, How can I fix that if the site request to use only 1 IP address to download the file ? As I want to use my MikroTik full bandwidth
