Downstream BGP
Hi, I have 5 BGP peers and need to control some traffic by manually form.
I controlled upstream traffic via mangle rules and static routes, but, how can I configured some kind of downstream traffic to receive them for a particular bgp peer ?.
up
we need bgp-communities support
already supported.
if you want to affect the incoming traffic you can only use as-path (padding) I believe.
Sam
And communities if your uplink supports this. Communities are some kind of tag.
With this tag your uplink can announce your Networks differently.
Stefan
