Downstream slowdown due to config
Let me start by thanking you for taking the time to read this.
I have had my 2011UiAS-2HnD for quite some years now and overall I am very happy with it.
The last couple of years, I have had a 1GB up and down fiber connection and the router just can’t really cope with it.
My config has grown over the years and to be honest, I have not really done a lot with Mikrotik lately. So when I finaly had enough and told myself I would go and tackle this problem, I quickly noticed that a lot of my mikrotik knowledge was lost. When I completely reset the router and keep it as basic as possible, I can get about 600MB down. With the attached config, I get 250 max and the CPU is on 100% all the time during download.
My provider has internet on vlan 34
I share my connection with my neighbor, he is on the 192.168.115.0/24 network.
Is there some glaring error I made in my config that causes the slowdown? I would love it if someone could point out the obvious errors I have made.
# oct/09/2018 09:40:54 by RouterOS 6.42.6
# software id = HXGG-XIIP
# model = 2011UiAS-2HnD
# serial number = 444A02XXXX
add fast-forward=no name=Bridge-Gast
add admin-mac=D4:CA:6D:1D:0F:34 auto-mac=no fast-forward=no mtu=1500 name=\
    bridge-local
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether6 ] name=ether6-master-local
set [ find default-name=ether7 ] name=ether7-slave-local
set [ find default-name=ether8 ] name=ether8-slave-local
set [ find default-name=ether9 ] name=ether9-slave-local
set [ find default-name=ether10 ] name=ether10-Gast
set [ find default-name=sfp1 ] disabled=yes
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=5 band=2ghz-b/g/n channel-width=\
    20/40mhz-eC country=netherlands disabled=no frequency=auto mode=ap-bridge \
    ssid="XXXXXX Onderkant" wireless-protocol=802.11
/interface vlan
add interface=ether1-gateway loop-protect-disable-time=0s \
    loop-protect-send-interval=0s name=VLAN34 vlan-id=34
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" \
    mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=\
    XXXXXxxxXXXX wpa2-pre-shared-key=XXXXXxxxXXXX
add authentication-types=wpa-psk,wpa2-psk eap-methods="" mode=dynamic-keys \
    name=GastenProfiel supplicant-identity=VuurMuur wpa-pre-shared-key=\
add authentication-types=wpa-psk,wpa2-psk eap-methods="" \
    management-protection=allowed mode=dynamic-keys name=\
    "Het Contoso Gasten" supplicant-identity="" wpa-pre-shared-key=\
/interface wireless
add disabled=no keepalive-frames=disabled mac-address=D6:CA:6D:1D:0F:3E \
    master-interface=wlan1 multicast-buffering=disabled name=\
    "Het Contoso Gasten" security-profile="Het Contoso Gasten" ssid=\
    "Het Contoso Gasten" wds-cost-range=0 wds-default-cost=0
add disabled=no mac-address=D6:CA:6D:1D:0F:3D master-interface=wlan1 name=\
    wlan2 security-profile=GastenProfiel ssid="Gasten Netwerk"
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add name=dhcp ranges=192.168.15.100-192.168.15.200
add name=dhcppoolgast ranges=192.168.115.50-192.168.115.200
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=\
    bridge-local lease-time=3d name=default
add address-pool=dhcppoolgast authoritative=after-2sec-delay disabled=no \
    interface=Bridge-Gast name=DHCPS_GAST
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/system logging action
add disk-file-count=5 disk-file-name=AccountLog name=AccountLog target=disk
add disk-file-count=50 disk-file-name=Firewall disk-lines-per-file=5000 name=\
    Firewall target=disk
/interface bridge filter
add action=drop chain=forward in-interface=wlan2
add action=drop chain=forward out-interface=wlan2
add bridge=bridge-local hw=no interface=ether2
add bridge=bridge-local hw=no interface=ether3
add bridge=bridge-local hw=no interface=ether4
add bridge=bridge-local hw=no interface=ether5
add bridge=bridge-local interface=ether6-master-local
add bridge=bridge-local hw=no interface=sfp1
add bridge=bridge-local interface=wlan1
add bridge=Bridge-Gast interface=wlan2
add bridge=Bridge-Gast hw=no interface=ether10-Gast
add bridge=bridge-local interface="Het Contoso Gasten"
add bridge=bridge-local interface=ether7-slave-local
add bridge=bridge-local interface=ether8-slave-local
add bridge=bridge-local interface=ether9-slave-local
set discover-interface-list=discover
add interface=sfp1 list=discover
add interface=ether2 list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=ether6-master-local list=discover
add interface=ether7-slave-local list=discover
add interface=ether8-slave-local list=discover
add interface=ether9-slave-local list=discover
add interface=ether10-Gast list=discover
add interface=wlan1 list=discover
add interface=bridge-local list=discover
add interface=wlan2 list=discover
add interface=VLAN34 list=discover
add interface=Bridge-Gast list=discover
add interface="Het Contoso Gasten" list=discover
add interface=ether2 list=mactel
add interface=ether3 list=mactel
add interface=ether2 list=mac-winbox
add interface=ether4 list=mactel
add interface=ether3 list=mac-winbox
add interface=ether5 list=mactel
add interface=ether4 list=mac-winbox
add interface=ether6-master-local list=mactel
add interface=ether5 list=mac-winbox
add interface=wlan1 list=mactel
add interface=sfp1 list=mactel
add interface=ether6-master-local list=mac-winbox
add interface=wlan2 list=mactel
add interface=wlan1 list=mac-winbox
add interface=sfp1 list=mac-winbox
add interface=wlan2 list=mac-winbox
/interface ovpn-server server
set certificate=cert_5 enabled=yes
/interface wireless access-list
add ap-tx-limit=1048576 client-tx-limit=1048576 interface=wlan2
add mac-address=AC:22:0B:64:B8:8F
add interface=wlan2
add address=192.168.15.254/24 comment="default configuration" interface=\
    ether2 network=192.168.15.0
add address=192.168.115.254/24 interface=Bridge-Gast network=192.168.115.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid interface=\
    ether1-gateway
add dhcp-options=hostname,clientid disabled=no interface=VLAN34
/ip dhcp-server lease
add address=192.168.15.224 client-id=1:0:c:29:56:84:f2 mac-address=\
    00:0C:29:56:84:F2 server=default
add address=192.168.15.112 client-id=\
    ff:2b:94:34:c1:0:2:0:0:ab:11:c5:ef:73:f1:6:1e:2b:a3 mac-address=\
    00:0C:29:89:5E:AC server=default
add address=192.168.15.103 client-id=1:74:c6:3b:9f:2:7b mac-address=\
    74:C6:3B:9F:02:7B server=default
add address=192.168.15.234 client-id=1:b8:27:eb:dd:a1:46 mac-address=\
    B8:27:EB:DD:A1:46 server=default
add address=192.168.15.251 client-id=1:5c:e2:8c:78:bd:a0 comment=\
    "Zyxel POE Switch" mac-address=5C:E2:8C:78:BD:A0 server=default
add address=192.168.15.253 comment=NAS mac-address=00:11:32:11:9B:6B
add address=192.168.15.241 client-id=1:38:af:29:46:83:3d comment=CAM01 \
    mac-address=38:AF:29:46:83:3D server=default
add address=192.168.15.242 client-id=1:38:af:29:46:83:55 comment=CAM02 \
    mac-address=38:AF:29:46:83:55 server=default
add address=192.168.15.243 client-id=1:38:af:29:46:83:2a comment=CAM03 \
    mac-address=38:AF:29:46:83:2A server=default
add address=192.168.15.249 client-id=1:e8:2a:ea:49:f1:7e mac-address=\
    E8:2A:EA:49:F1:7E server=default
add address=192.168.15.250 always-broadcast=yes client-id=1:0:e0:4c:68:2:81 \
    mac-address=00:E0:4C:68:02:81 server=default
add address=192.168.15.244 client-id=1:b8:27:eb:e0:c7:eb comment=PiCam \
    mac-address=B8:27:EB:E0:C7:EB server=default
add address=192.168.115.10 always-broadcast=yes client-id=1:0:11:32:8c:89:7a \
    comment=NAS-XxxXXX mac-address=00:11:32:8C:89:7A server=DHCPS_GAST
add address=192.168.15.102 mac-address=00:17:88:B3:7D:50 server=default
add address=192.168.15.106 client-id=1:0:11:32:37:d2:27 mac-address=\
    00:11:32:37:D2:27 server=default
add address=192.168.15.0/24 comment="default configuration" dns-server=\
    192.168.15.254,8.8.8.8 domain=thuis.lan gateway=192.168.15.254 netmask=24
add address=192.168.115.0/24 dns-server=192.168.115.254 domain=gast.lan \
    gateway=192.168.115.254 netmask=24
set allow-remote-requests=yes servers=192.168.15.254
/ip dns static
add address=192.168.15.253 name=XXXXXX
add address=192.168.15.234 name=XXXXXX
add address=192.168.15.251 name=XXXXXX
add address=192.168.15.250 name=XXXX
add address=192.168.15.254 name=XXXXXX
add address=192.168.15.241 name=cam01.XXXXXX.nl
add address=192.168.15.242 name=cam02.XXXXXX.nl
add address=192.168.15.243 name=cam03.XXXXXX.nl
add address=192.168.115.10 name=XXXXXX.synology.me
/ip firewall address-list
add address=62.XXXXXX.152.XXXXXX list=SMD-No-Logging
add address=40.XXXXXX.154.XXXXXX list=SMD-No-Logging
add address=40.XXXXXX.156.XXXXXX list=SMD-No-Logging
add address=40.XXXXXX.156.XXXXXX list=SSH-Allow-Home
add address=40.XXXXXX.154.XXXXXX list=SSH-Allow-Home
add address=62.XXXXXX.152.XXXXXX list=SSH-Allow-Home
add action=log chain=forward disabled=yes dst-address=0.0.0.0/0 dst-port=\
    !5938 log=yes log-prefix=VMWARE protocol=tcp src-address=192.168.15.250
add action=drop chain=forward disabled=yes dst-address=192.168.15.0/24 \
    src-address=192.168.115.0/24
add action=drop chain=forward disabled=yes dst-address=192.168.115.0 \
    src-address=192.168.15.0
add action=drop chain=forward comment="Block CAM01 out" dst-address=0.0.0.0/0 \
    log=yes log-prefix=CAM01 src-address=192.168.15.241
add action=drop chain=forward comment="Block CAM02 out" dst-address=0.0.0.0/0 \
    log=yes log-prefix=CAM02 src-address=192.168.15.242
add action=drop chain=forward comment="Block CAM03 out" dst-address=0.0.0.0/0 \
    log=yes log-prefix=CAM03 src-address=192.168.15.243
add action=accept chain=input comment="default configuration" protocol=icmp
add action=accept chain=input comment="default configuration" \
    connection-state=established
    connection-state=related
add action=accept chain=input comment="Winbox from WAN" dst-port=8291 \
    protocol=tcp
add action=accept chain=forward comment="default configuration" \
add action=drop chain=input comment="default configuration" in-interface=\
    VLAN34
add action=drop chain=forward comment="default configuration" \
    connection-state=invalid
add action=masquerade chain=srcnat comment="default configuration" \
    out-interface=VLAN34
add action=dst-nat chain=dstnat comment=SynBackup1 dst-port=6281 \
    in-interface=VLAN34 protocol=tcp to-addresses=192.168.15.253 to-ports=\
    6281
add action=dst-nat chain=dstnat comment=SynBackup2 dst-port=873 in-interface=\
    VLAN34 protocol=tcp to-addresses=192.168.15.253 to-ports=873
add action=dst-nat chain=dstnat comment=Domoticz dst-port=8080 in-interface=\
    VLAN34 log=yes log-prefix=domo-nat-in protocol=tcp to-addresses=\
    192.168.15.234 to-ports=8080
add action=dst-nat chain=dstnat comment=BlueIris dst-port=1118 in-interface=\
    VLAN34 log=yes log-prefix=BlueIris-nat-in protocol=tcp src-port="" \
    to-addresses=192.168.15.250 to-ports=1118
add action=dst-nat chain=dstnat comment="Poort80 Syno" disabled=yes dst-port=\
    80 in-interface=VLAN34 protocol=tcp to-addresses=192.168.15.253 to-ports=\
    80
add action=dst-nat chain=dstnat comment="Poort 443 Syno" disabled=yes \
    dst-port=443 in-interface=VLAN34 protocol=tcp to-addresses=192.168.15.253 \
    to-ports=443
add action=dst-nat chain=dstnat comment="SABNZB Synology" dst-port=7654 \
    in-interface=VLAN34 protocol=tcp src-address=163.XXXXXX.155.XXXXXX \
    to-addresses=192.168.15.253 to-ports=8080
add action=dst-nat chain=dstnat comment="Synology HTTP" dst-port=5000 \
    to-addresses=192.168.15.253 to-ports=5000
add action=dst-nat chain=dstnat comment="Synology HTTPS" dst-port=5001 \
    to-addresses=192.168.15.253 to-ports=5001
add action=dst-nat chain=dstnat comment="OpenVPN 2 NAS" dst-port=1194 \
    in-interface=VLAN34 log=yes log-prefix=VPN protocol=udp to-addresses=\
    192.168.15.253 to-ports=1194
add action=dst-nat chain=dstnat comment="SynoBackup1 XXXXXX" dst-port=6282 \
    in-interface=VLAN34 protocol=tcp to-addresses=192.168.115.10 to-ports=\
    6281
add action=dst-nat chain=dstnat comment="SynoBackup2 XXXXXX" dst-port=874 \
    in-interface=VLAN34 protocol=tcp to-addresses=192.168.115.10 to-ports=873
add action=dst-nat chain=dstnat comment="SyvoDSFile XXXXXX" dst-port=5501 \
    5001
add action=dst-nat chain=dstnat comment="SynoBackup1 XXXXXX" dst-port=6283 \
    in-interface=VLAN34 port="" protocol=tcp to-addresses=192.168.15.106 \
    to-ports=6281
add action=dst-nat chain=dstnat comment="Syno Backup 2 XXXXXX" dst-port=875 \
    in-interface=VLAN34 protocol=tcp to-addresses=192.168.15.106 to-ports=873
/ip upnp
set enabled=yes
/lcd
set enabled=no touch-screen=disabled
/lcd interface pages
set 0 interfaces="sfp1,ether1-gateway,ether2,ether3,ether4,ether5,ether6-maste\
    r-local,ether7-slave-local,ether8-slave-local,ether9-slave-local,ether10-G\
    ast"
/system clock
set time-zone-name=Europe/Amsterdam
/system identity
set name=VuurMuur-XXXXXX
/system logging
add action=AccountLog topics=system,error,critical
add action=AccountLog topics=system,info,account
add action=Firewall prefix=Firewall topics=firewall
/system ntp client
set enabled=yes primary-ntp=129.250.35.251 secondary-ntp=94.212.40.117 \
    server-dns-names=nl.pool.ntp.org
/system routerboard settings
set silent-boot=no
/system scheduler
add comment="Update Dynamic DNS entry every 30 minutes" interval=30m name=\
    "Update FreeDNS" on-event="/tool fetch url=\"http://freedns.afraid.org/dyn\
    amic/update.php\XXXXXX"" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=\
    may/19/2014 start-time=18:45:27
add comment=09:36:33 interval=30s name=InlogMail on-event=":local scheduleName\
    \_\"InlogMail\"\r\
    \n:local emailAddress \"XXXXX@XXXXXX.nl\"\r\
    \n:local startBuf [:toarray [/log find message~\"logged in\" || message~\"\
    login failure\"]]\r\
    \n:local removeThese (\"whatever string you want\")\r\
    \n \r\
    \n:local lastTime [/system scheduler get [find name=\"\$scheduleName\"] co\
    mment]\r\
    \n \r\
    \n:local currentBuf \"\"; :set currentBuf [:toarray \$currentBuf]\r\
    \n \r\
    \n:foreach i in=\$startBuf do={\r\
    \n  :local toggle 1\r\
    \n  :foreach j in=[:toarray \$removeThese] do={\r\
    \n    :if ([:typeof [:find [/log get \$i message] \"\$j\"]] = \"num\") do=\
    {\r\
    \n      :set toggle 0\r\
    \n    }\r\
    \n  }\r\
    \n  :if (\$toggle = 1) do={\r\
    \n    :set currentBuf (\$currentBuf , \$i)\r\
    \n  }\r\
    \n}\r\
    \n \r\
    \n:local currentLineCount [ :len \$currentBuf ]\r\
    \n  \r\
    \nif (\$currentLineCount > 0) do={\r\
    \n   :local currentTime \"\$[ /log get [ :pick \$currentBuf (\$currentLine\
    Count -1) ] time ]\"\r\
    \n  \r\
    \n   :if ([:len \$currentTime] = 15 ) do={\r\
    \n      :set currentTime [ :pick \$currentTime 7 15 ]\r\
    \n   }\r\
    \n     \r\
    \n   :local output \"\$currentTime \$[/log get [ :pick \$currentBuf (\$cur\
    rentLineCount-1) ] message ]\"\r\
    \n     \r\
    \n   :if (([:len \$lastTime] < 1) || (([:len \$lastTime] > 0) && (\$lastTi\
    me != \$currentTime))) do={\r\
    \n      /system scheduler set [find name=\"\$scheduleName\"] comment=\$cur\
    rentTime\r\
    \n      /tool e-mail send to=\"\$emailAddress\" subject=\"MikroTik alert \
    \$currentTime\" body=\"\$output\"\r\
    \n   }\r\
    \n}" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive \
    start-date=jun/02/2014 start-time=13:56:40
add comment="Send Config Backup once a week to mail" interval=1w name=\
    sched_backup_mail on-event=EmailBackup policy=\
    jan/05/1970 start-time=22:53:00
/system script
add name="WOL HTPC" owner=admin policy=\
    reboot,read,write,policy,test,password,sniff,sensitive source=\
    "/tool wol mac=D4:3D:7E:56:D4:72 interface=bridge-local"
add name="Update FreeDNS" owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive source="/tool f\
    etch url=\"http://freedns.afraid.org/dynamic/update.php\XXXXX""
add name="WOL HTPC-Slaapkamer" owner=AdminUser policy=\
    "/tool wol mac=3c:97:0e:3f:c1:55 interface=bridge-local"
add name="WOL NAS" owner=admin policy=\
    "/tool wol mac=00:11:32:11:9b:6b interface=bridge-local"
add name=EmailBackup owner=AdminUser policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive source="/system\
    \_backup save name=mailbackup password=routerconfbu123; \\\
    \n/tool e-mail send to=\"XXXXX@XXXXX.nl\" subject=([/system identity get\
    \_name] . \" Backup \" . [/system clock get date]) file=mailbackup;\
    \n\
    \n\
    \n"
add name="WOL PC-EJL" owner=AdminUser policy=\
    "/tool wol mac=44-8A-5B-9E-BF-B7 interface=bridge-local"
add name=WOL-LOG owner=AdminUser policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive source=\
    "/tool wol mac=9C-EB-E8-14-F1-AA interface=bridge-local"
add name="WOL Random" owner=AdminUser policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=\
    "/tool wol mac=D8-50-E6-A4-10-E4 interface=bridge-local"
/tool e-mail
set address=smtp.XXXXX.nl from=XXXXX@XXXXX.nl
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
First action to take would be enabling fasttrack.
You could gather your cameras in an address list and aggregate your single forward drop rules for the cams to one with matching the address list.
And finally, a 2011 will be too weak to reliably cope with a 1Gig link. Probably a 3011 or 4011 would do better for zou in thi scase.
-Chris
Thank you for your reply.
I’ll try to make these changes tonight. I’ll be happy if I can squeeze out around 500 per sec.
Thanks,
I enabled Fasttrack and went to around 550Mbps at 95% cpu.
Big difference. Good enough for me now, means I don’t have to upgrade to a 4011 yet :slight_smile:
