Thanks Mrz. here is the output:
AP:
set default authentication-types="" eap-methods=passthrough group-ciphers="" \
group-key-update=5m interim-update=0s management-protection=disabled \
management-protection-key="" mode=none name=default \
radius-eap-accounting=no radius-mac-accounting=no \
radius-mac-authentication=no radius-mac-caching=disabled \
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=\
none static-key-0="" static-key-1="" static-key-2="" static-key-3="" \
static-sta-private-algo=none static-sta-private-key="" \
static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=\
none tls-mode=no-certificates unicast-ciphers="" wpa-pre-shared-key="" \
wpa2-pre-shared-key=""
/interface wireless
set 0 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no \
antenna-gain=0 antenna-mode=ant-a area="" arp=enabled band=2ghz-onlyn \
basic-rates-a/g=6Mbps basic-rates-b=1Mbps comment="" compression=no \
country="south africa" default-ap-tx-limit=0 default-authentication=yes \
default-client-tx-limit=0 default-forwarding=yes dfs-mode=none \
disable-running-check=no disabled=no disconnect-timeout=3s \
frame-lifetime=0 frequency=2437 frequency-mode=manual-txpower hide-ssid=\
no ht-ampdu-priorities=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 \
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 \
ht-extension-channel=above-control ht-guard-interval=any ht-rxchains=0 \
ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mc\
s-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15" ht-txchains=0 \
hw-fragmentation-threshold=disabled hw-protection-mode=none \
hw-protection-threshold=0 hw-retries=4 mac-address=00:0C:42:3A:ED:01 \
max-station-count=2007 mode=station-wds mtu=1500 name=wlan1 \
on-fail-retry-time=100ms periodic-calibration=default \
periodic-calibration-interval=60 preamble-mode=both \
proprietary-extensions=post-2.9.25 radio-name=000C423AED01 rate-set=\
default scan-list=default security-profile=default ssid=wt1 \
station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=\
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=\
1Mbps,2Mbps,5.5Mbps,11Mbps tx-power-mode=default update-stats-interval=\
disabled wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=\
100 wds-ignore-ssid=no wds-mode=disabled wmm-support=disabled
/interface wireless manual-tx-power-table
set wlan1 comment="" manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,\
6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps\
:17,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-7:0,HT20-8:\
0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0,HT40-8:0"
/interface wireless nstreme
set wlan1 comment="" disable-csma=no enable-nstreme=no enable-polling=yes \
framer-limit=3200 framer-policy=none
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=\
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
Station:
/interface wireless
hw-protection-threshold=0 hw-retries=4 mac-address=00:0C:42:3A:ED:18 \
max-station-count=2007 mode=ap-bridge mtu=1500 name=wlan1 \
proprietary-extensions=post-2.9.25 radio-name=000C423AED18 rate-set=\
disabled wds-cost-range=50-150 wds-default-bridge=bridge1 \
wds-default-cost=100 wds-ignore-ssid=no wds-mode=dynamic wmm-support=\
disabled
set wlan1 comment="" disable-csma=no enable-nstreme=no enable-polling=no \
00:11:95:9F:1C:C4 filter-mac=00:00:00:00:00:00 frame-size=300 \
frames-per-second=25 receive-all=yes ssid-all=yes
Also, if its recommended that I use MPLS or EoIP like uldis suggested, then please let me know.
Thank you
