I found a few posts about this topic, but they are a bit old or left behind.
What do you use to draw your network diagrams except for Visio. Are there MikroTik stencils for other software solutions? What do they use in MikroTik documents?
What would you recommend that supports layers and is fast of course. I need it to draw the layer 1 topology and then 2 VLANs on separate layers.
