Draytek Vigor 120 PPoA>PPPoE bridge
I’ve seen a few posts recommending these on the forum so I purchased one myself. No joy getting it to work with Mikrotik router though.
It works fine with Windows PPPoE client, cheap routers - Netgear etc but although Mikrotik establishes a PPPoE session it will not pass any traffic.
Can anybody help?
Hi Trisc,
I use the DV120 routers successfully with Mikrotik, please post screenshot of the WAN configuration screen on the Draytek, and your /ip firewall entries, as well as your PPPoE setup. I should be able to figure it out for you.
Also, what firmware version is on the Draytek ?
I did not realise PPPoA was used in the UK, I thought it was all RFC1483 bridging(aka MPoA)…
Regards,
Andrew
Thanks - it was just a simple masquerade error after all - on the wrong interface. I am impressed with the Draytek though - like having a built in modem in routerOS.
Yes PPPoA is standard in UK.
