Dreadful wi-fi on hAP lite (10% ping loss, average latency 600 ms)
We have a bunch of hAP lite (RB941-2nD) routers. Each serves as a gateway for 1-5 devices total. Usually it’s an IP camera connected by cable and a laptop connected by wifi.
ROS 6.34.8 (latest).
[admin@MikroTik] > /interface wireless print detail
 0  R name="wlan1" mtu=1500 l2mtu=1600 mac-address=CC:2D:E0:61:EA:73 arp=enabled
      interface-type=Atheros AR9300 mode=ap-bridge ssid="WD642" frequency=auto band=2ghz-g/n
      channel-width=20/40mhz-XX secondary-channel="" scan-list=default wireless-protocol=802.11 vlan-mode=no-tag
      vlan-id=1 wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled
      default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
      hide-ssid=no security-profile=wlan_security_profile_main compression=no
/interface wireless spectral-history screenshot is attached to this message.
Laptop is placed in 2-3 meters away from hAP lite. In given config, we have no loss, ping latency min 1ms, max 800ms, average 100 ms.
Tried to change channel-width to 20mhz (should’ve create less interference), and ping loss went to 10%, average latency 600 ms. Pinging the hAP lite, of course.
Is there something we can do to make hAP lite provide stable wifi for 1 laptop? Also tried to ping hAP lite from a tablet, same thing. Please help to fix this.
