Anyone know the RouterOS v3.0 or v3.17 supports this device “Sierra Wireless MC8775 PCI Express Mini Card”?
But why i don’t see this device appear on RouterOS v3.17? And could you please tell me how i configure APN and Dial # for this 3G card?
Thanks!
I have no idea about your APN and other parameters, you will have to ask your phone company to help with those.
If your card is in the Wiki as “working” and you use the latest RouterOS version, but the card is not in the Port list - email support with your supout.rif file
Hi all,
I use Mikrotik router OS 3.17 , and use with Sierra Wireless MC8775 3g pci card . i use command “port print” i did not see any port available for that .
Anyone have any idea to configure that device with Mikrotik router OS
send a supout.rif file from this PC to support, we will see why it’s not in your port list
i install mikrotik v3.17 on motherboard alix6b2. and when i do system resources i see my Sierra Wireless Card (MC8775) lies there under USB tab (see Sierra Wireless Detect.jpg). and i do Ports i don’t see any port that referenced to this Sierra Wireless Card (see Port Desont’s Show.jpg). So, i can’t create ppp connection through this port. Do you have any idea? as i see on the supported hardware page, i see MC8775 card is in there, but why it doesn’t show on the Ports list?
Thanks for quick reply!
and what are those three usb ports?? use the last one i think ‘usb3’
Ok! I’ll try this. thanks!
Next, i have a alix6b2 board and i insert the sim card into the board and my sim card use “web” apn to connect to the internet. Do you know where on this mikrotik routeros i can configure this “web” apn. I can’t find the place to set this apn.
Thank
what is “web” APN? It works with ALIX?
