Hello. I worked on this project about a half year and now I publish it on Google Play.
This is configuration utility for RouterOS for Android.
With DroidBox you can set up your test and production devices on the go.
It works via API, so API port needs to be opened on the device you want connect to.
https://play.google.com/store/apps/details?id=com.pinchuk.droidbox.app
Check out my new application.
