Hi, i have tried to mangle these rules :
0 p2p=all-p2p action=passthrough mark-connection=P2P
1 connection=P2P action=accept mark-flow=Flow-P2P
and drop it using :
0 flow=Flow-P2P action=drop
But my client still could get through on some P2P program (such as src.port udp 12005). Is there any other effective way to block the P2P traffic? Thank you.
drop using
/ip firewall filter add chain=forward p2p=all-p2p src-address=0.0.0.0/0 action=drop
But when the ares use the UDP port 0, the detect p2p doesn’t work.
I test it and the ares is eat me the bandwidth
Maxi
Yeah, some of the P2P program uses UDP port and my router couldn’t drop the packet. Is there any ways to completely dropping all the P2P packet? Thank you
If you have a linux firewall server then use Shoreline firewall for load balancing it works gr8. if you need help MSN me chris@eccsystems.co.za
