A customer has 3 wAP ac running ROS 6.39.1. All setup with same SSID / wpa2 key so that clients can move around the area and connect to the AP with strongest signal. Problem is that they have 6 sonos devices, and these seems to frequently connect to the first AP they see, not the one with the strongest signal at their location. In the status of the wAP ac’s I frequently see sonos devices with a signal strength of -90 or worse.
I want to automatically disconnect devices with weak signals. The wiki has an example of such using access lists.
https://wiki.mikrotik.com/wiki/Manual:Interface/Wireless#Access_List
So, I run the commands from the wiki on all the wAP ac’s:
/interface wireless access-list
add interface=wlan1 signal-range=-75
add authentication=no forwarding=no interface=wlan2 signal-range=-120..-76
When the commands run, the AP disconnects all clients. Within seconds the devices reconnects, and I still see devices with signal strength of -92 or worse. If I kick them out manually, they connect to another AP, and things are fine, for a while. But within hours the devices again has reconnected to the AP with weak signal. So the code quoted seems to not work as intended.
Does anyone know how to make this work?
