hi
how i can auto add failure request ip in mikrotik firewall for drop input request for 1 hour
for example this user test-user and Calling-Station-Id = “2.180.224.69” ip
Remove your Public IP from your text.
You might want to change your PPTP to something more secure. PPTP discontinued.
Is this topic related to your other post? DO NOT DROP THE ICMP IF YOU RUN A VPN SERVER
You could adapt this script(this is for IPsec fail logins, you could change the parameters to suit your PPTPs error. Following this, you need to run a scheduler for the script too.
:local logMessage ""
:local logIp ""
/log
:foreach i in=[find where message~"phase1 negotiation failed\\." or message~"SPI.*not regist" or message~"Invalid exchange"] do={
:set logMessage [get $i message]
:if ($logMessage~"phase1 negotiation failed\\.") do={
:set logIp [:toip [:pick $logMessage -1 [:find $logMessage " "]]]
:if ([:len [/ip fire addr find where list="Black List - Bots" address=$logIp]] < 1) do={
/ip fire addr add address=$logIp list="Black List - Bots" timeout=7d
:log info message="script=Black List - Bots src_ip=$logIp why=negotiation_failed"
:if ($logMessage~"SPI .* not registered for") do={
:set logIp [:toip [:pick $logMessage ([:find $logMessage "for "]+4) [:find $logMessage "["]]]
:log info message="script=Black List - Bots src_ip=$logIp why=SPI_not_registered"
:if ($logMessage~"Invalid exchange") do={
:set logIp [:toip [:pick $logMessage ([:find $logMessage "from "]+5) [:find $logMessage "["]]]
:log info message="script=Black List - Bots src_ip=$logIp why=Invalid_exchange"
Hello good time
This issue is not related to the other post
I have pptp and l2tp protocols on the server
But some users who do not exist in the server send many requests to the server
And they interfere with the Radius server
I want to block repeated unauthorized requests for a period of time
