Hello
Yes I am using NV2 ...
Site 1 Netmetal
jul/23/2017 14:38:52 by RouterOS 6.39.2
software id = J6PE-3A8Y
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled arp-timeout=auto
auto-mac=yes disabled=no fast-forward=no forward-delay=15s
max-message-age=20s mtu=auto name=bridge1 priority=0x8000 protocol-mode=
rstp transmit-hold-count=6
set [ find default-name=ether1 ] advertise=
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled
arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1600 loop-protect=on
loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=
D4:CA:6D:03:C8:4B master-port=none mtu=1500 name=ether1 orig-mac-address=
D4:CA:6D:03:C8:4B rx-flow-control=off speed=100Mbps tx-flow-control=off
set [ find default-name=sfp1 ] advertise=
disabled=no full-duplex=yes l2mtu=1600 loop-protect=default
D4:CA:6D:03:C8:4C master-port=none mtu=1500 name=sfp1 orig-mac-address=
D4:CA:6D:03:C8:4C rx-flow-control=off speed=1Gbps tx-flow-control=off
/ip neighbor discovery
set ether1 discover=yes
set sfp1 discover=yes
set bridge1 discover=yes
/queue interface
set bridge1 queue=no-queue
set (unknown) name=all
set [ find default=yes ] authentication-types="" eap-methods=passthrough
group-ciphers=aes-ccm group-key-update=5m interim-update=0s
management-protection=disabled mode=none mschapv2-username="" name=
default radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=
none static-sta-private-algo=none static-transmit-key=key-0
supplicant-identity=MikroTik tls-certificate=none tls-mode=
no-certificates unicast-ciphers=aes-ccm
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=none allow-sharedkey=
no ampdu-priorities=0 amsdu-limit=8192 amsdu-threshold=8192 antenna-gain=
0 area="" arp=enabled arp-timeout=auto band=5ghz-onlyac basic-rates-a/g=
6Mbps bridge-mode=enabled channel-width=20/40/80mhz-eCee compression=no
country=no_country_set default-ap-tx-limit=0 default-authentication=yes
default-client-tx-limit=0 default-forwarding=yes disable-running-check=no
disabled=no disconnect-timeout=3s distance=dynamic frame-lifetime=0
frequency=5400 frequency-mode=superchannel frequency-offset=0
guard-interval=any hide-ssid=no ht-basic-mcs=
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs="mcs-0,mc
s-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,m
cs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-2
3" hw-fragmentation-threshold=disabled hw-protection-mode=none
hw-protection-threshold=0 hw-retries=7 interworking-profile=disabled
keepalive-frames=enabled l2mtu=1600 mac-address=D4:CA:6D:03:C8:4D
max-station-count=2007 mode=ap-bridge mtu=1500 multicast-buffering=
enabled multicast-helper=default name=wlan1 nv2-cell-radius=35 nv2-qos=
default nv2-queue-count=2 nv2-security=disabled on-fail-retry-time=100ms
preamble-mode=both radio-name=D4CA6D03C84D rate-selection=advanced
rate-set=default rx-chains=0,1 scan-list=default security-profile=default
ssid=MYBCDC-50-18-3-BH station-bridge-clone-mac=00:00:00:00:00:00
station-roaming=enabled supported-rates-a/g=
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps tdma-period-size=4
tx-chains=0,1 tx-power-mode=default update-stats-interval=disabled
vht-basic-mcs=mcs0-7 vht-supported-mcs=mcs0-9,mcs0-9,mcs0-9 vlan-id=1
vlan-mode=no-tag wds-cost-range=50-150 wds-default-bridge=none
wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled
wireless-protocol=nv2 wmm-support=disabled wps-mode=push-button
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9M
bps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:
17,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,H
T40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-
7:17"
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=
3200 framer-policy=none
set wlan1 discover=yes
/ip dhcp-client option
set clientid code=61 name=clientid value="0x01$(CLIENT_MAC)"
set hostname code=12 name=hostname value="$(HOSTNAME)"
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=
hotspot html-directory-override="" http-cookie-lifetime=3d http-proxy=
0.0.0.0:0 login-by=cookie,http-chap name=default rate-limit=""
smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=yes address-list="" idle-timeout=none
!insert-queue-before keepalive-timeout=2m mac-cookie-timeout=3d name=
default !parent-queue !queue-type shared-users=1 status-autorefresh=1m
transparent-proxy=no
/ip ipsec mode-config
set [ find default=yes ] name=request-only
/ip ipsec policy group
set [ find default=yes ] name=default
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=
aes-128-cbc lifetime=30m name=default pfs-group=modp1024
/ppp profile
set *0 address-list="" !bridge !bridge-horizon !bridge-path-cost
!bridge-port-priority change-tcp-mss=yes !dns-server !idle-timeout
!incoming-filter !insert-queue-before !interface-list !local-address
name=default on-down="" on-up="" only-one=default !outgoing-filter
!parent-queue !queue-type !rate-limit !remote-address !session-timeout
use-compression=default use-encryption=default use-mpls=default use-upnp=
default !wins-server
set *FFFFFFFE address-list="" !bridge !bridge-horizon !bridge-path-cost
name=default-encryption on-down="" on-up="" only-one=default
!outgoing-filter !parent-queue !queue-type !rate-limit !remote-address
!session-timeout use-compression=default use-encryption=yes use-mpls=
default use-upnp=default !wins-server
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=pcq name=pcq-upload-default pcq-burst-rate=0 pcq-burst-threshold=0
pcq-burst-time=10s pcq-classifier=src-address pcq-dst-address-mask=32
pcq-dst-address6-mask=128 pcq-limit=50KiB pcq-rate=0
pcq-src-address-mask=32 pcq-src-address6-mask=128 pcq-total-limit=2000KiB
set 6 kind=pcq name=pcq-download-default pcq-burst-rate=0
pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=dst-address
pcq-dst-address-mask=32 pcq-dst-address6-mask=128 pcq-limit=50KiB
pcq-rate=0 pcq-src-address-mask=32 pcq-src-address6-mask=128
set 7 kind=none name=only-hardware-queue
set 8 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 9 kind=pfifo name=default-small pfifo-limit=10
/queue interface
set ether1 queue=only-hardware-queue
set sfp1 queue=only-hardware-queue
set wlan1 queue=wireless-default
/routing bgp instance
set default as=65530 client-to-client-reflection=yes !cluster-id
!confederation disabled=no ignore-as-path-len=no name=default out-filter=
"" redistribute-connected=no redistribute-ospf=no redistribute-other-bgp=
no redistribute-rip=no redistribute-static=no router-id=0.0.0.0
routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never !domain-id
!domain-tag in-filter=ospf-in metric-bgp=auto metric-connected=20
metric-default=1 metric-other-ospf=auto metric-rip=20 metric-static=20
!mpls-te-area !mpls-te-router-id name=default out-filter=ospf-out
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no
!routing-table !use-dn
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=
backbone type=default
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0 authentication-protocol=MD5
encryption-protocol=DES name=public read-access=yes security=none
write-access=no
/system logging action
set 0 memory-lines=1000 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=1000
disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote=0.0.0.0 remote-port=514 src-address=
0.0.0.0 syslog-facility=daemon syslog-severity=auto syslog-time-format=
bsd-syslog target=remote
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,w
eb,sniff,sensitive,api,romon,tikapp,!ftp,!write,!policy,!dude" skin=
default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pa
ssword,web,sniff,sensitive,api,romon,tikapp,!ftp,!policy,!dude" skin=
default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,
winbox,password,web,sniff,sensitive,api,romon,dude,tikapp" skin=default
/caps-man aaa
set interim-update=disabled mac-caching=disabled mac-format=XX:XX:XX:XX:XX:XX
/caps-man manager
set ca-certificate=none certificate=none enabled=no package-path=""
require-peer-certificate=no upgrade-policy=none
/caps-man manager interface
set [ find default=yes ] disabled=no forbid=no interface=all
/certificate settings
set crl-download=yes
add auto-isolate=no bridge=bridge1 disabled=no edge=auto external-fdb=auto
horizon=none interface=wlan1 path-cost=10 point-to-point=auto priority=
0x80
horizon=none interface=ether1 path-cost=10 point-to-point=auto priority=
0x80
/interface bridge settings
set allow-fast-path=yes use-ip-firewall=no use-ip-firewall-for-pppoe=no
use-ip-firewall-for-vlan=no
set enabled=auto generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-max-retrans-timeout=5m tcp-syn-received-timeout=5s
tcp-syn-sent-timeout=5s tcp-time-wait-timeout=10s tcp-unacked-timeout=5m
udp-stream-timeout=3m udp-timeout=10s
/ip neighbor discovery settings
set default=yes default-for-dynamic=no
/ip settings
set accept-redirects=no accept-source-route=no allow-fast-path=yes
arp-timeout=30s icmp-rate-limit=10 icmp-rate-mask=0x1818 ip-forward=yes
max-neighbor-entries=8192 route-cache=yes rp-filter=no secure-redirects=
yes send-redirects=yes tcp-syncookies=no
/interface l2tp-server server
set allow-fast-path=no authentication=pap,chap,mschap1,mschap2
caller-id-type=ip-address default-profile=default-encryption enabled=no
keepalive-timeout=30 max-mru=1450 max-mtu=1450 max-sessions=unlimited
mrru=disabled use-ipsec=no
/interface ovpn-server server
set auth=sha1,md5 cipher=blowfish128,aes128 default-profile=default enabled=
no keepalive-timeout=60 mac-address=FE:BA:2E:62:42:44 max-mtu=1500 mode=
ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption
enabled=no keepalive-timeout=30 max-mru=1450 max-mtu=1450 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=
default enabled=no force-aes=no keepalive-timeout=60 max-mru=1500
max-mtu=1500 mrru=disabled pfs=no port=443 tls-version=any
verify-client-certificate=no
/interface wireless access-list
add ap-tx-limit=0 authentication=yes client-tx-limit=0 disabled=no
forwarding=yes interface=wlan1 mac-address=4C:5E:0C:1A:95:44
private-algo=none signal-range=-120..120 !time vlan-id=1 vlan-mode=no-tag
forwarding=yes interface=wlan1 mac-address=00:0C:42:8D:44:3F
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless cap
set bridge=none caps-man-addresses="" caps-man-certificate-common-names=""
caps-man-names="" certificate=none discovery-interfaces="" enabled=no
interfaces="" lock-to-caps-man=no static-virtual=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=10.100.122.78/19 disabled=no interface=ether1 network=10.100.96.0
/ip cloud
set ddns-enabled=no update-time=yes
/ip cloud advanced
set use-local-address=no
/ip dhcp-server config
set store-leases-disk=5m
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB
max-concurrent-queries=100 max-concurrent-tcp-sessions=20
max-udp-packet-size=4096 query-server-timeout=2s query-total-timeout=10s
servers=""
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes sip-timeout=1h
set pptp disabled=no
set udplite disabled=no
set dccp disabled=no
set sctp disabled=no
/ip hotspot service-port
/ip hotspot user
set [ find default=yes ] comment="counters and limits for trial users"
disabled=no name=default-trial
/ip ipsec policy
set 0 disabled=no dst-address=::/0 group=default proposal=default protocol=
all src-address=::/0 template=yes
/ip ipsec user settings
set xauth-use-radius=no
/ip proxy
set always-from-cache=no anonymous=no cache-administrator=webmaster
cache-hit-dscp=4 cache-on-disk=no cache-path=web-proxy enabled=no
max-cache-object-size=2048KiB max-cache-size=unlimited
max-client-connections=600 max-fresh-time=3d max-server-connections=600
parent-proxy=:: parent-proxy-port=0 port=8080 serialize-connections=no
src-address=::
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443
set api address="" disabled=no port=8728
set winbox address="" disabled=no port=8291
set api-ssl address="" certificate=none disabled=no port=8729
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=
all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/pub disabled=no
max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip ssh
set always-allow-password-login=no forwarding-enabled=no host-key-size=2048
strong-crypto=no
/ip traffic-flow
set active-flow-timeout=30m cache-entries=32k enabled=no
inactive-flow-timeout=15s interfaces=all
/ip traffic-flow ipfix
set bytes=yes dst-address=yes dst-address-mask=yes dst-mac-address=yes
dst-port=yes first-forwarded=yes gateway=yes icmp-code=yes icmp-type=yes
igmp-type=yes in-interface=yes ip-header-length=yes ip-total-length=yes
ipv6-flow-label=yes is-multicast=yes last-forwarded=yes nat-dst-address=
yes nat-dst-port=yes nat-src-address=yes nat-src-port=yes out-interface=
yes packets=yes protocol=yes src-address=yes src-address-mask=yes
src-mac-address=yes src-port=yes tcp-ack-num=yes tcp-flags=yes
tcp-seq-num=yes tcp-window-size=yes tos=yes ttl=yes udp-length=yes
/ip upnp
set allow-disable-external-interface=no enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0
use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-circuit-id-in-nas-port-id=no
use-radius=no
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s
multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m
gateway-selection=no-gateway origination-interval=5s preferred-gateway=
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no
redistribute-connected=no redistribute-ospf=no redistribute-static=no
routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-community=public
trap-generators="" trap-target="" trap-version=1
/system clock
set time-zone-autodetect=no time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=
"jan/01/1970 00:00:00" time-zone=+00:00
/system health
set fan-on-threshold=40C fan-switch=on
/system identity
set name=MikroTik
/system leds
set 0 disabled=no interface=sfp1 leds=sfp1-led type=interface-activity
set 1 disabled=no interface=wlan1 leds=led1,led2,led3,led4,led5 type=
wireless-signal-strength
/system leds settings
set all-leds-off=never
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=yes primary-ntp=10.100.123.211 secondary-ntp=0.0.0.0
server-dns-names=""
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
/system routerboard settings
set boot-device=nand-if-fail-then-ethernet boot-protocol=bootp
force-backup-booter=no protected-routerboot=disabled silent-boot=no
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=
100
/tool e-mail
set address=0.0.0.0 from=<> port=25 start-tls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool romon
set enabled=no id=00:00:00:00:00:00 secrets=""
/tool romon port
set [ find default=yes ] cost=100 disabled=no forbid=no interface=all
secrets=""
/tool sms
set allowed-number="" channel=0 interface=none keep-max-sms=0
receive-enabled=no
/tool sniffer
set file-limit=1000KiB file-name="" filter-cpu="" filter-direction=any
filter-interface="" filter-ip-address="" filter-ip-protocol=""
filter-ipv6-address="" filter-mac-address="" filter-mac-protocol=""
filter-operator-between-entries=or filter-port="" filter-stream=no
memory-limit=100KiB memory-scroll=yes only-headers=no streaming-enabled=
no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-max=100us measure-out-of-order=yes
stats-samples-to-keep=100 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s
use-radius=no
Site 2 Netmetal
jul/23/2017 07:48:37 by RouterOS 6.39.2
software id = FW3Q-ECYC
00:0C:42:8D:44:3D master-port=none mtu=1500 name=ether1 orig-mac-address=
00:0C:42:8D:44:3D rx-flow-control=off speed=100Mbps tx-flow-control=off
00:0C:42:8D:44:3E master-port=none mtu=1500 name=sfp1 orig-mac-address=
00:0C:42:8D:44:3E rx-flow-control=off speed=1Gbps tx-flow-control=off
/queue interface
/interface wireless
frequency=5600 frequency-mode=superchannel frequency-offset=0
keepalive-frames=enabled l2mtu=1600 mac-address=00:0C:42:8D:44:3F
max-station-count=2007 mode=station-bridge mtu=1500 multicast-buffering=
enabled multicast-helper=default name=wlan1 nv2-cell-radius=30 nv2-qos=
preamble-mode=both radio-name=000C428D443F rate-selection=advanced
rate-set=default rx-chains=0,1 scan-list=default,4900-6050
security-profile=default ssid=MYBCDC-50-18-3-BH station-bridge-clone-mac=
00:00:00:00:00:00 station-roaming=enabled supported-rates-a/g=
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps tdma-period-size=2
wireless-protocol=nv2-nstreme wmm-support=disabled wps-mode=push-button
7:17"
/ip hotspot profile
/ip ipsec proposal
/ppp profile
/queue type
/queue interface
routing-table=""
/routing ospf area
/snmp community
write-access=no
/user group
default
default
/caps-man aaa
/caps-man manager
0x80
0x80
/ip settings
no keepalive-timeout=60 mac-address=FE:6F:EE:6D:2F:24 max-mtu=1500 mode=
/ip accounting
add address=10.100.122.131/19 disabled=no interface=ether1 network=
10.100.96.0
/ip cloud
/ip cloud advanced
servers=""
/ip hotspot user
/ip ipsec policy
/ip proxy
src-address=::
/ip service
/ip smb
all
/ip smb shares
/ip smb users
/ip socks
/ip ssh
strong-crypto=no
/ip traffic-flow
/ip upnp
/mpls
/mpls interface
/mpls ldp
/port firmware
/ppp aaa
use-radius=no
/radius incoming
multiplier=5
/routing mme
/routing rip
/snmp
/system clock
set time-zone-autodetect=yes time-zone-name=America/Vancouver
/system health
/system identity
set name=MikroTik
/system leds
/system logging
/system note
/system ntp client
server-dns-names=""
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
0.0.0.0 user=""
/system watchdog
100
/tool e-mail
/tool graphing
/tool mac-server
set enabled=yes
/tool romon
/tool romon port
secrets=""
/tool sms
receive-enabled=no
/tool sniffer
/user aaa
use-radius=no
Site 2 RB 911G HPnacD
jul/23/2017 07:57:15 by RouterOS 6.39.2
software id = GHB9-UJK0
4C:5E:0C:1C:C5:55 rx-flow-control=off speed=100Mbps tx-flow-control=off
/queue interface
/interface wireless
frequency=5350 frequency-mode=superchannel frequency-offset=0
keepalive-frames=enabled l2mtu=1600 mac-address=4C:5E:0C:1C:C5:56
max-station-count=2007 mode=bridge mtu=1500 multicast-buffering=enabled
multicast-helper=default name=wlan1 nv2-cell-radius=15 nv2-qos=default
preamble-mode=both radio-name=4C5E0C1CC556 rate-selection=advanced
ssid=MYBCDC-5-26-0-BH station-bridge-clone-mac=00:00:00:00:00:00
tx-chains=0,1 tx-power=30 tx-power-mode=all-rates-fixed
update-stats-interval=disabled vht-basic-mcs=mcs0-7 vht-supported-mcs=
mcs0-9,mcs0-9,mcs0-9 vlan-id=1 vlan-mode=no-tag wds-cost-range=50-150
wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=
disabled wireless-protocol=nv2 wmm-support=disabled wps-mode=push-button
7:17"
/ip hotspot profile
/ip ipsec proposal
aes-256-cbc,aes-192-cbc,aes-128-cbc lifetime=30m name=default pfs-group=
modp1024
/ppp profile
/queue type
add kind=pcq name="2-Mbps Up" pcq-burst-rate=0 pcq-burst-threshold=0
pcq-dst-address6-mask=64 pcq-limit=50000KiB pcq-rate=2M
pcq-src-address-mask=32 pcq-src-address6-mask=64 pcq-total-limit=
15000000KiB
add kind=pcq name="3-Mbps Up" pcq-burst-rate=0 pcq-burst-threshold=0
pcq-dst-address6-mask=64 pcq-limit=50000KiB pcq-rate=3M
15000000KiB
add kind=pcq name="4-Mbps Up" pcq-burst-rate=0 pcq-burst-threshold=0
pcq-dst-address6-mask=64 pcq-limit=50000KiB pcq-rate=4M
15000000KiB
add kind=pcq name="10-Mbps Down" pcq-burst-rate=0 pcq-burst-threshold=0
pcq-burst-time=10s pcq-classifier=dst-address pcq-dst-address-mask=32
pcq-dst-address6-mask=64 pcq-limit=50000KiB pcq-rate=10M
15000000KiB
add kind=pcq name="18-Mbps Down" pcq-burst-rate=0 pcq-burst-threshold=0
pcq-dst-address6-mask=64 pcq-limit=50000KiB pcq-rate=18M
15000000KiB
add kind=pcq name="22-Mbps Down" pcq-burst-rate=0 pcq-burst-threshold=0
pcq-dst-address6-mask=64 pcq-limit=50000KiB pcq-rate=22M
15000000KiB
add kind=pcq name="25-Mbps Down" pcq-burst-rate=0 pcq-burst-threshold=0
pcq-dst-address6-mask=64 pcq-limit=50000KiB pcq-rate=25M
15000000KiB
set 12 kind=pcq name=pcq-upload-default pcq-burst-rate=0 pcq-burst-threshold=
0 pcq-burst-time=10s pcq-classifier=src-address pcq-dst-address-mask=32
set 13 kind=pcq name=pcq-download-default pcq-burst-rate=0
set 14 kind=none name=only-hardware-queue
set 15 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 16 kind=pfifo name=default-small pfifo-limit=10
/queue interface
/queue simple
add bucket-size=0.1/10 burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s
disabled=no limit-at=0/0 max-limit=2M/10M name=queue119 packet-marks=""
parent=none priority=8/8 queue="2-Mbps Up/10-Mbps Down" target=
10.100.96.99/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue118 packet-marks=""
10.100.96.98/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue117 packet-marks=""
10.100.96.97/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue116 packet-marks=""
10.100.96.96/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue115 packet-marks=""
10.100.96.95/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue114 packet-marks=""
10.100.96.94/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue113 packet-marks=""
10.100.96.93/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue112 packet-marks=""
10.100.96.92/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue111 packet-marks=""
10.100.96.91/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue110 packet-marks=""
10.100.96.90/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue109 packet-marks=""
10.100.96.89/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue108 packet-marks=""
10.100.96.88/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue107 packet-marks=""
10.100.96.87/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue106 packet-marks=""
10.100.96.86/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue105 packet-marks=""
10.100.96.85/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue104 packet-marks=""
10.100.96.84/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue103 packet-marks=""
10.100.96.83/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue102 packet-marks=""
10.100.96.82/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue101 packet-marks=""
10.100.96.81/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue100 packet-marks=""
10.100.96.80/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue99 packet-marks=""
10.100.96.79/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue98 packet-marks=""
10.100.96.78/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue97 packet-marks=""
10.100.96.77/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue96 packet-marks=""
10.100.96.76/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue95 packet-marks=""
10.100.96.75/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue94 packet-marks=""
10.100.96.74/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue93 packet-marks=""
10.100.96.73/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue92 packet-marks=""
10.100.96.72/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue91 packet-marks=""
10.100.96.71/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue90 packet-marks=""
10.100.96.70/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue89 packet-marks=""
10.100.96.69/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue88 packet-marks=""
10.100.96.68/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue87 packet-marks=""
10.100.96.67/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue86 packet-marks=""
10.100.96.66/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue85 packet-marks=""
10.100.96.65/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue84 packet-marks=""
10.100.96.64/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue83 packet-marks=""
10.100.96.63/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue82 packet-marks=""
10.100.96.62/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue81 packet-marks=""
10.100.96.61/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue80 packet-marks=""
10.100.96.60/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue79 packet-marks=""
10.100.96.59/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue78 packet-marks=""
10.100.96.58/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue77 packet-marks=""
10.100.96.57/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue76 packet-marks=""
10.100.96.56/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue75 packet-marks=""
10.100.96.55/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue74 packet-marks=""
10.100.96.54/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue73 packet-marks=""
10.100.96.53/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue72 packet-marks=""
10.100.96.52/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue71 packet-marks=""
10.100.96.51/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue70 packet-marks=""
10.100.96.50/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue69 packet-marks=""
10.100.96.49/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue68 packet-marks=""
10.100.96.48/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue67 packet-marks=""
10.100.96.47/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue66 packet-marks=""
10.100.96.46/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue65 packet-marks=""
10.100.96.45/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue64 packet-marks=""
10.100.96.44/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue63 packet-marks=""
10.100.96.43/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue62 packet-marks=""
10.100.96.42/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue61 packet-marks=""
10.100.96.41/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue60 packet-marks=""
10.100.96.40/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue59 packet-marks=""
10.100.96.39/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue58 packet-marks=""
10.100.96.38/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue57 packet-marks=""
10.100.96.37/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue56 packet-marks=""
10.100.96.36/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue55 packet-marks=""
10.100.96.35/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue54 packet-marks=""
10.100.96.34/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue53 packet-marks=""
10.100.96.33/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue52 packet-marks=""
10.100.96.32/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue51 packet-marks=""
10.100.96.31/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue50 packet-marks=""
10.100.96.30/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue49 packet-marks=""
10.100.96.29/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue48 packet-marks=""
10.100.96.28/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue47 packet-marks=""
10.100.96.27/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue46 packet-marks=""
10.100.96.26/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue45 packet-marks=""
10.100.96.25/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue44 packet-marks=""
10.100.96.24/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue43 packet-marks=""
10.100.96.23/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue42 packet-marks=""
10.100.96.22/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue41 packet-marks=""
10.100.96.21/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue40 packet-marks=""
disabled=no limit-at=0/0 max-limit=2M/10M name=queue39 packet-marks=""
10.100.96.20/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue38 packet-marks=""
10.100.96.19/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue37 packet-marks=""
10.100.96.18/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue36 packet-marks=""
10.100.96.17/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue35 packet-marks=""
10.100.96.16/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue34 packet-marks=""
10.100.96.15/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue33 packet-marks=""
10.100.96.14/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue32 packet-marks=""
10.100.96.13/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue31 packet-marks=""
10.100.96.12/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue13 packet-marks=""
10.100.96.11/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue30 packet-marks=""
10.100.96.10/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue29 packet-marks=""
10.100.96.9/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue28 packet-marks=""
10.100.96.8/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue27 packet-marks=""
10.100.96.7/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue26 packet-marks=""
10.100.96.6/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue25 packet-marks=""
10.100.96.5/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue24 packet-marks=""
10.100.96.4/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue23 packet-marks=""
10.100.96.3/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue22 packet-marks=""
10.100.96.2/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue121 packet-marks=""
10.100.107.19/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name="Darlene Jodouin"
packet-marks="" parent=none priority=8/8 queue="2-Mbps Up/10-Mbps Down"
target=10.100.106.133/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name="Penny Harris"
target=10.100.107.134/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue6 packet-marks=""
10.100.107.201/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue7 packet-marks=""
10.100.107.202/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue8 packet-marks=""
10.100.107.203/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue9 packet-marks=""
10.100.107.204/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue10 packet-marks=""
10.100.107.205/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue11 packet-marks=""
10.100.107.206/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue12 packet-marks=""
10.100.107.207/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue120 packet-marks=""
10.100.107.208/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue14 packet-marks=""
10.100.107.209/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue15 packet-marks=""
10.100.107.210/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue16 packet-marks=""
10.100.107.211/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue17 packet-marks=""
10.100.107.212/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue18 packet-marks=""
10.100.107.213/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue19 packet-marks=""
10.100.107.214/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue20 packet-marks=""
10.100.107.215/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/10M max-limit=2M/10M name="Donald Finllaysen"
target=10.100.107.216/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/10M max-limit=2M/10M name="Terry Gold"
target=10.100.106.231/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/10M max-limit=2M/10M name="Scott McCuaig"
target=10.100.106.232/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/10M max-limit=2M/10M name="Ken MacDonald"
target=10.100.106.233/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/10M max-limit=2M/10M name=McLean packet-marks=""
10.100.107.234/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name="Lawrence Rae"
target=10.100.107.235/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name="Burned out Gas Station"
target=10.100.107.236/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name="Michelle Mohr"
target=10.100.107.237/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name="Clayton Kendrick"
target=10.100.107.239/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue5 packet-marks=""
10.100.107.246/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue4 packet-marks=""
10.100.107.247/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue3 packet-marks=""
10.100.107.248/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue2 packet-marks=""
10.100.107.249/32 !time total-queue="10-Mbps Down"
disabled=no limit-at=0/0 max-limit=2M/10M name=queue1 packet-marks=""
10.100.107.250/32 !time total-queue="10-Mbps Down"
routing-table=""
/routing ospf area
/snmp community
write-access=no
/user group
default
default
/caps-man aaa
/caps-man manager
0x80
0x80
set allow-fast-path=yes use-ip-firewall=yes use-ip-firewall-for-pppoe=no
/ip settings
no keepalive-timeout=60 mac-address=FE:18:12:F2:94:38 max-mtu=1500 mode=
/ip accounting
add address=10.100.122.130/19 disabled=no interface=ether1 network=
10.100.96.0
/ip cloud
/ip cloud advanced
servers=""
/ip hotspot user
/ip ipsec policy
/ip proxy
src-address=::
/ip service
/ip smb
all
/ip smb shares
/ip smb users
/ip socks
/ip ssh
strong-crypto=no
/ip traffic-flow
/ip upnp
/mpls
/mpls interface
/mpls ldp
/port firmware
/ppp aaa
use-radius=no
/radius incoming
multiplier=5
/routing mme
/routing rip
/snmp
/system clock
set time-zone-autodetect=no time-zone-name=America/Vancouver
/system health
/system identity
set name=MikroTik
/system leds
set 0 disabled=no interface=wlan1 leds=led1,led2,led3,led4,led5 type=
/system logging
/system note
/system ntp client
server-dns-names=""
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
0.0.0.0 user=""
/system watchdog
100
/tool e-mail
/tool graphing
/tool mac-server
set enabled=yes
/tool romon
/tool romon port
secrets=""
/tool sms
receive-enabled=no
/tool sniffer
/user aaa
use-radius=no
