Drop traffic of the IPs that haven't a simple queue
Hi all,
Are there the possibility to deny the traffic of the IPs that haven’t a simple queue???
I’ve a class C network and I want to allow the traffic only of the IPs in use. And all IPs in use have a simple queue associate with then.
Thanks in advance,
Fabricio
I am also interested in that issue. Please, advise us.
thanks
setup a simple queue with a target equal to the entire subnet and set the max-rate-limit to 10k/10k Make sure this queue is at the bottom of the list.. this way if a client doesn’t have a entry in the queue the max bandwidth will be 10kbps/10kbps..
At least that’s one way of doing it… You could also create a firewall rule that blocks access from un-authorized MAC/IP addresses to the WAN and dst-nat’s port 80 requests to a webpage that allows them to signup for service..
Just a few idea’s.
I’m creating the simple queues using a web page and a perl script.
How can I have sure that the simple queue with 10kbps/10kbps is in the end of the queues??? There are a form to set the queue number???
But I link much more of the firewall rule. Can you tell me a bit more about this???
How can I setup the firewall rules???
Will I need to create a rule for each client allowed? If it’s true, will I need of dynamic rules, correct?
And how can I redirect the users to a web page that show a message for then?
Thanks again
Fabricio
