Could you help me understand why this drop in transmission (TX) occurs across all my CRS326 units—on every Ethernet port as well as on the SFP interfaces?
Thank you in advance.
Is Flow control enabled and working on both sides?
Hi Daryl,
I think I see something in your screenshot. If you add up Tx Unicast + Broadcast + Multicast:
71132679 + 11841100 + 3359880 = 86333659
That is exactly the second number in the Tx/Drop Packet row. So I don't think you dropped 86 million packets. My guess is that 86333659 is your sent packets and 612172 is the real drop count, so the two numbers are shown in reverse order.
I can't prove that from my side. On my CRS310 (7.25.1), tx-packet is the same sum on the ports I checked, but I have no drops there. You can check it in the terminal, because it shows both counters by name:
/interface ethernet print stats where name=ether1
Then compare tx-packet and tx-drop-packet.
If I'm right, you are losing about 0.7% of the packets on this port. The dropped packets are large, about 1460 bytes on average (853.8 MiB / 612172). To me that looks like a full buffer and not a defect, for example when a 10G uplink sends faster than a 1G port can pass on.
You see it on all ports, so maybe traffic is being flooded to every port. You could look at a port with an idle device. If the tx counters go up quickly there, I would look for unknown unicast flooding.
These counters run since the last reset or reboot, so the question is if they are still going up. Which CRS326 model do you have, what are your link speeds, and do your users notice any problems?
This is only my guess, I could be wrong. English is not my first language, so I used a translation help.
Regards
As @M.Breuer1975 wrote, the drop rate shown is 0.7%. Unfortunately, WinBox 3 has been neglected for a while and for these new stats fields it doesn't understand the layout sent by RouterOS. As a result, the order of the fields you are looking at are actually reversed. The real drop number is the smaller one of the pair (listed first by WinBox 3, listed 2nd by WinBox 4).
You should view these tabs under WinBox 4 instead. But even there, the labelling is suboptimal. See this other thread:
Thanks for clarifying! That explains the confusing figures in WinBox 3. I’ll check the statistics in WinBox 4 as well. Good to know the actual drop rate is indeed 0.7%.
Flow control is active on both switches.
Hi Daryl,
Flow control doesn't rule out a full buffer. It works per link, both ends have to agree, and it doesn't guarantee zero drops. You can check if it is really active on a port:
/interface ethernet monitor ether1 once
Look at tx-flow-control and rx-flow-control. On a port to a PC or server, this also depends on that device.
Then run this twice during normal traffic, a few minutes apart:
Compare tx-drop-packet, tx-pause and rx-pause. If tx-drop-packet stays the same, those are old drops. If it goes up, the port is still overloaded at times.
A tx-pause of 0 doesn't prove much. In this thread, users measured a CRS310 where tx-pause stayed at 0 and packets were still dropped with flow control on:
Also, a pause stops all traffic on that link, including traffic for other ports that are not busy. So I wouldn't expect flow control to solve this on the links between your switches.
Which CRS326 model do you have, what are your link speeds, and do your users notice any problems? If nobody notices anything and the counter only grows slowly, I would leave it as it is.
The counter names are from my CRS310 with 7.25.1, I haven't tested this on a CRS326. English is not my first language, so I used a translation help.
Regards
