First, please accept my apologies in case this has been discussed before, I searched and could not find anything that discusses this specific issue.
Second, please note that this is not your typical “how do I protect against rogue DHCP servers” topic that seems abundant around here. This is more interesting, please read on ![]()
TL;DR: I need to drop ethernet frames based on MAC address and not IP packets. Can my Mikrotik RB750 do that? I’m running ROS 6.40.1
So anyway, In our new office building, internet service is given using a building-wide LAN. Unfortunately, there seems to be rogue DHCP servers unknowingly ran by people who apparently use their ADSL router as a switch. As there is no way to know where they are short of knocking on everyone’s doors and searching for suspicious devices, I’m trying to use a Mikrotik RB-750 as our border router in order to isolate our network from the rest of the building.
Of course, rogue DHCP servers are confusing Mikrotik’s DHCP client as well, so I need to block these based on MAC address. So I ran wireshark a bit and identified the MAC addresses of the DHCP servers I want to ignore. I then went to IP > Firewall > Filter and added DROP rules to the INPUT chain for packets coming in from these mac addresses. The rules at first seemed to work fine (the counters are going up). I then enabled DHCP debug logging via System > Logging and added an entry for the DHCP topic. After that, when I go to IP > DHCP Client and click on “Renew Lease” I noticet that I keept seeing DHCP OFFER packets from rogue DHCP servers.
Then it hit me: IP filtering can’t work before the IP subsystem is up. So I need to drop Ethernet frames and not IP packets. Can my Mikrotik do that?
Thanks a lot for reading thus far!
