I’m trying to do a simple QoS implementation. I’ve read the wiki article http://wiki.mikrotik.com/wiki/DSCP_based_QoS_with_HTB and cobbled together a simplified version of BrotherDust’s suggested implementation.
The script successfully builds the firewall mangle and the queue tree. I can see data moving at the mangle, but nothing seems to be moving into or out of the queue tree.
#### Set Variables
#Set interface here to whatever is the WAN port
:local outboundInterface "ether1"
#Set bandwidth of the interface (suggest leaving at 0 = no limit)
:local interfaceBandwidth 0
#Set where in the chain the packets should be mangled
:local mangleChain postrouting
#### First Create the Firewall Mangle
# Zero (0) packets don't have any DSCP data in their header and will be low priority
/ip firewall mangle add action=mark-packet chain=postrouting comment=dscp.0 disabled=no \
dscp=0 new-packet-mark=dscp.0 passthrough=no
# 46 packets are maked as EF (Expedited Forwarding) this is standard practice for VOIP devices - high priority
/ip firewall mangle add action=mark-packet chain=postrouting comment=dscp.46 disabled=no \
dscp=46 new-packet-mark=dscp.46 passthrough=no
# 48 packets are routing data, how MikroTik marks its OSPF exchanges - highest priority
/ip firewall mangle add action=mark-packet chain=postrouting comment=dscp.48 disabled=no \
dscp=48 new-packet-mark=dscp.48 passthrough=no
# All other traffic will be normal priority
:for x from 1 to 45 do={/ip firewall mangle add action=mark-packet chain=postrouting \
comment=dscp.1-45 disabled=no dscp=$x new-packet-mark=dscp.other passthrough=no}
/ip firewall mangle add action=mark-packet chain=postrouting comment=dscp.47 disabled=no \
dscp=47 new-packet-mark=dscp.other passthrough=no
:for x from 49 to 63 do={/ip firewall mangle add action=mark-packet chain=postrouting \
comment=dscp.49-63 disabled=no dscp=$x new-packet-mark=dscp.other passthrough=no}
#### Set up the queue tree
# Add a base queue to the queue tree for the outbound interface
/queue tree add \
max-limit=$interfaceBandwidth \
name=Outbound \
parent=$outboundInterface \
priority=1
# Add the queue for the MikroTik's routing exchanges, set to highest priortiy
/queue tree add \
name=MikroTikRouting \
parent=Outbound \
priority=1 \
packet-mark=("dscp_48") \
queue=ethernet-default
# Add the queue for VOIP traffic, set to high priority
/queue tree add \
name=VOIP \
parent=Outbound \
priority=2 \
packet-mark=("dscp_46") \
# Add the queue for all other traffic, set to normal priority
/queue tree add \
name=Other \
parent=Outbound \
priority=3 \
packet-mark=("dscp_other") \
# Add the queue packets without DSCP in the header, set to lowest priority
/queue tree add \
name=noDSCP \
parent=Outbound \
priority=4 \
packet-mark=("dscp_none") \
What am I missing?
Any suggestions, improvements or comments are welcome.
