hey guys
what is the best and accurate setting MTU my mikrotik behind DSL connection.
thanks
hey guys
thanks
This depends on your DSL Provider and the MTU they give you. Typically, 1420-1440 works well, but if it is a true bridge DSL then 1500 should be fine. If it is a PPPoE session it would make a difference as well.
the current situation is bridge mode and no ppoe session, ok will stick on 1500.
thanks gmsmstr
