DSL Behind Modem
Hi All
Please forgive me, still a bit new to mikrotik.
I’m trying to get to my adsl router web page via my mikrotik, unfortunately no luck.
I’ve read through the forums, just not getting it.
So my setup.
ADSL Router: 10.0.0.1 , 255.255.255.0
Mikrotik:
Mode: Router , PPPoE
Local Network
IP: 10.0.0.2, 255.255.255.0(/24)
DSL Cable connected to ether1 on Mikrotik
Switch connected to ether2 on Mikrotik
Laptop/PC’s connected to the switch
Everything works 100% on the local subnet which it’s getting from the mikrotik, ping, dns, internet etc.
I just cant seem to access my ADSL router webpage.
Any help will be highly appreciated.
You need to either set a different subnet for the modem (or LAN) or bridge ether1 and ether2 so they are both in the same broadcast domain.
Right now you’ve got 10.0.0.0/24 for both the modem (ether1) and your lan (ether2)
Also, you probably will need to set up a SNAT rule to be able to access the modem (since usually they don’t allow to add static routes so it will be able to reach your LAN subnet).
