DSL downlaod Size limiting.
AOA
i have 2 DSL lines with 4MB bandwidth.i use them with Wan Load lancing.
now my ISP charge me double if i download more then 300GB for 1DSL line.
plz help me.
i want to apply download size limit on each DSL so that after 299GB it auto stop download and browsing.
:frowning:
thanks for all mikrotik forum teem
Simplest way to do this would be to add a simple queue to your metered DSL lines and keep track of the data recorded by this, noting this value will reset if the router is repowered.
Alternatively you might be able to respurpose a script like this: http://www.mikrotik-routeros.com/?p=24 to record and report back to you when your links reach certain limits.
This script also records the data in the comment field so negates majority of any lost data due to a router reboot.
