DSL Fail over
Hi All,
I am well aware of the unfortunate fact that MikroTik does not have DSL support.
We currently use MikroTik quite widely as a CPE, however with our high profile customers we are using Cisco 2800 series routers so we can have auto fail over from an Ethernet link to DSL. Now we have a large number of mid range customers that cannot afford to fork out for a Cisco router but would like DSL fail over. MikroTik is the obvious answer however it is a little messy / tacky having some cheapo DSL modem hanging off the MikroTik. Has anyone got a reasonably professional solution for having a MikroTik + DSL modem in bridge mode ?
thanks
MikroTik supports PPPoE which most US-based providers utilize. You can turn a DSL modem into bridge mode, and thus terminate the PPPoE session directly on the MikroTik making it ‘support’ DSL. If your DSL provider uses PPPoA, you’re out of luck.
People report success with these - http://www.draytek.co.uk/products/vigor120.html
