DSL failover question
Got an RB750 and looking to connect two DSL lines with autofailover.
I’ve seen this article:
http://wiki.mikrotik.com/wiki/Two_gateways_failover
My setup is a little different though
Connection 1 is fine, it’s normal ADSL and has a router on the end and a LAN IP (192.168.1.1)
Connection 2 is fibre and uses PPPoE, the VDSL modem connected to this doesn’t have an IP, it’s transparent, somehow I need to use the Mikrotik as the PPPoE client as well.
Is that config possible?
Yes, create the PPPoE client. On the Advanced Tab check “use default router” and the change the distance to 2 or whatever you like. That will give you the same result as the example you cited. Don’t forget that you need to NAT rules, one for each connection.
