DSL half speed through RB133, full speed direct to notebook
Hello all. This is my first post, so using this basics forum. And thank you in advance!
I have used a Mikrotik network for a few years that consists of bridged AP/WDS CPE’s. This is per the WIKI for MESH. I have 6 clients that are non line of sight. Most cannot get a signal from the dsl AP. So one client is 4 hops from the dsl site. This has worked good so far. I did have a Buffalo router between the dsl modem and the RB133 AP.
Now I have enabled PPPoE, on the RB133 at the dsl site, and NAT to the bridge with the wlan and 2 of Ethernets as bridge ports. The PPPoe is on an Ethernet port not associated with the bridge. I have DHCP server enabled on the bridge.
The dsl service is 3Mb. When using a PPPoE client on a notebook W2K, I see 3Mb down using NetPerSec local network monitoring utility. However, and here is my issue, when I connect the notebook to one of the bridged Ethernet ports on the RB133 I can get Interent access, but downloads are at 1.5Mb. Why the halving of the speed?
are pings OK?
[admin@Gateway3] > ping http://www.google.com count=5
64.233.169.99 64 byte ping: ttl=245 time=70 ms
64.233.169.99 64 byte ping: ttl=245 time=54 ms
64.233.169.99 64 byte ping: ttl=245 time=76 ms
64.233.169.99 64 byte ping: ttl=245 time=51 ms
64.233.169.99 64 byte ping: ttl=245 time=82 ms
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 51/66.6/82 ms
Thanks again for any help.
I will copy from telnet the settings:
[admin@Gateway3] interface> print
Flags: X - disabled, D - dynamic, R - running
 #    NAME                         TYPE             RX-RATE    TX-RATE    MTU
 0  R ether1                       ether            0          0          1480
 1  R ether2                       ether            0          0          1500
 2  R ether3                       ether            0          0          1500
 3  R hub                          wds              0          0          1500
 4  R pppoe-out1                   pppoe-out        0          0          1480
 5  R bridge2                      bridge           0          0          1500
 6  R srsin                        wds              0          0          1500
 7  R wlan1                        wlan             0          0          1500
[admin@Gateway3] ip> address print
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
 0   192.168.1.1/24     192.168.1.0     192.168.1.255   bridge2
 1 D xxx.xxx.xxx.xx/32  xxx.xxx.xxx.x   0.0.0.0         pppoe-out1
[admin@Gateway3] interface bridge> print
 0  R name="bridge2" mtu=1500 arp=enabled mac-address=00:0C:42:15:38:BC
      protocol-mode=rstp priority=0x8000 auto-mac=yes
      admin-mac=00:00:00:00:67:65 max-message-age=20s forward-delay=15s
      transmit-hold-count=6 ageing-time=5m
[admin@Gateway3] interface wireless> print
 0  R name="wlan1" mtu=1500 mac-address=00:15:6D:93:06:03 arp=enabled
      disable-running-check=no interface-type=Atheros AR5213
      radio-name="gateway3" mode=ap-bridge ssid="MikroTik" area=""
      frequency-mode=manual-txpower country=no_country_set antenna-gain=0
      frequency=2427 band=2.4ghz-b/g scan-list=default rate-set=configured
      supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
      supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps basic-rates-b=1Mbps
      basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic
      tx-power=28 tx-power-mode=card-rates noise-floor-threshold=default
      periodic-calibration=default periodic-calibration-interval=60
      burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=static
      wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
      wds-ignore-ssid=no update-stats-interval=disabled
      default-authentication=no default-forwarding=yes default-ap-tx-limit=0
      default-client-tx-limit=0 proprietary-extensions=post-2.9.25
      hide-ssid=no security-profile=default disconnect-timeout=15s
      on-fail-retry-time=100ms preamble-mode=both compression=no
      allow-sharedkey=no
[admin@Gateway3] ip firewall nat> print
 0   chain=srcnat out-interface=pppoe-out1 limit=10000,50000
     dst-limit=10000,50000,dst-address/1m40s packet-size=0-1500
     action=masquerade
[admin@Gateway3] ip dhcp-server> print
 #   NAME             INTERFACE RELAY           ADDRESS-POOL LEASE-TIME ADD-ARP
 0   dhcp1            bridge2                   dhcp_pool1   3d         yes
[admin@Gateway3] queue interface> print
 # INTERFACE  QUEUE
 0 ether1     default
 1 ether2     ethernet-default
 2 ether3     ethernet-default
 3 hub        wireless-default
 4 pppoe-out1 default
 5 bridge2    default
 6 srsin      default
 7 wlan1      default
I should post that OS is 2.9.38
If any more info is needed to debug this setup please ask.
TNX
Hi ;
what is this ? could you explain excatly why you use the nat in this way ? :open_mouth: :open_mouth:
reply required .
with best reards .
ahmedsaffar76,
I am not versed well enough to know other ways to use NAT. So I used the application example from:
http://www.mikrotik.com/testdocs/ros/2.9/ip/nat.php
/ip firewall nat add chain=srcnat action=masquerade out-interface=Public
I input with winbox, and increased the limits in hopes that would effect the throughput, but it didn’t.
In what way are thinking I should use it?
Thanks for your interest.
Can anyone suggest where I might look for the slowdown? In the netpersec utility’s speed graph the download speed flat-tops at 1.5Mb/s, but if I have the notebook PC’s ethernet directly connected to the dsl modem I see the graph flat-top at 3Mb/s. I don’t want to add the Buffalo router back in there to do what the RB133 should be able to do, do I?
Any ideas?
