DSL line MT450G Cant set gateway IP
I can’t see where to set the Gateway IP for the eth1 interface that is connected to my DSL modem. I added the ip address using winbox but there is no field for gateway. My ISP gave me the following
199.170.240.65 ip
255.255.255.192 mask (26 CIDR I believe)
199.170.240.126 gateway
I put these in my pc and connect to DSL modem get right on internet. Try to plug these into MT and no connection to internet. I think it needs to have this gateway put somewhere, but I cannot find where.
Thanks in advance.
You need to go into IP routes and add a default route with that gateway IP.
Put 0.0.0.0/0 into Dst Address
and then put 199.170.240.126 into Gateway
Hope that helps
Nick.
That did it, thanks. Had a brain freeze should of known better. :smiley:
