I am wanting to nat out the dsl line until it goes down and then static route out another port to our t1’s for a failover. The reason for static routing on our main backbone is because we have a netequalizer on it and it will see everyones ip if we use static versus nat. Then the next problem is trying to monitor the access points that are plugged into the ethernet ports of the rb532. I do have routes setup so I can log into them but when applied to intermapper it only sees the routerboard. example monitor this device (10.0.200.36:59174) this will log me into 192.168.17.4 but when used in intermapper it only monitors 10.0.200.36. Any suggestions welcome. Thanks
I found the answers to my problems.
