DSL over PPPoE + backup 3G
Is it possible on MikroTik OS to set up 3G (over USB) connection as an automatic backup if internet connection via PPPoE connection breaks.
Howdy,
yes it is possible. I set this up quickly as a test on our office router recently.
Basically you assign a default route using, for example ppp-out1 as the 3G connection, and assign a larger distance than the pppoe connection.
For example:
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=aaa.bbb.ccc.ddd scope=30 target-scope=10
add disabled=yes distance=2 dst-address=0.0.0.0/0 gateway=ppp-out1 scope=30 target-scope=10
The second entry is disabled as I an not actually using it now. The distance is set to 2 which is larger than 1 so this route will be used as a backup.
Of course your gateway will be different.
Hope this helps.
Thanks. It is working well.
Hi I am trying to do this but I have a problem with this scenario. The routes are assigned dynamically.
Any ideas.
Hi
I had same issues, but I figured out that the dynamic routes for ppp-out connections are managed on the interface dialog.
You can set the default-rout distance (for dynamically associated route) from the PPP menu under your ppp-out1 interface settings.
Good luck
