Hi all, running ROS v6.41 on hEX.
Attempting to assign a public static IP from my ISP but failing miserably and cannot see the wood for the trees. Current setup is:
vigor 120 dsl modem–> pppoe-out1/eth1
eth2 is LAN
DHCP/src_nat setup.
At this stage internet connected and servicing LAN however I cannot see where I can now assign the /29 block I have been given by my ISP? The “local address” assigned to the pppoe-out1 interface is not part of the allocated /29.
Config export below.. any help gratefully received!!!
# model = RouterBOARD 750G r3
set [ find default-name=ether1 ] comment=Internet
set [ find default-name=ether2 ] comment=Lan
set [ find default-name=ether5 ] comment=Backup
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 keepalive-timeout=60 \
name=pppoe-out1 use-peer-dns=yes user=\
"userhere"
/ip hotspot profile
add name=pool_ws ranges=192.168.11.100-192.168.11.254
add name=pool_backup ranges=192.168.200.10-192.168.200.20
add address-pool=pool_ws authoritative=after-2sec-delay disabled=no interface=\
ether2 name=dhcp_ws
add address-pool=pool_backup authoritative=after-2sec-delay disabled=no \
interface=ether5 name=dhcp_backup
add address=192.168.11.1/24 interface=ether2 network=192.168.11.0
add address=192.168.200.1/24 interface=ether5 network=192.168.200.0
/ip dhcp-server lease
add address=192.168.11.80 mac-address=B8:27:EB:70:E5:A7 server=dhcp_ws
add address=192.168.11.0/24 dns-server=192.168.11.1 gateway=192.168.11.1
add address=192.168.200.0/24 dns-server=192.168.200.1 gateway=192.168.200.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip firewall address-list
add address=192.168.11.0/24 list=LAN_NETS
add address=192.168.200.0/24 list=LAN_NETS
add action=accept chain=input comment="Allow input established, related" \
connection-state=established,related in-interface=pppoe-out1 protocol=tcp
add action=accept chain=forward comment="Allow forward established, related" \
add action=accept chain=input comment="Allow ping" in-interface=pppoe-out1 \
protocol=icmp
add action=drop chain=input comment="Drop input invalid" connection-state=\
invalid in-interface=pppoe-out1
add action=drop chain=forward comment="Drop forward invalid" connection-state=\
add action=drop chain=forward comment="Drop DNS NOT local networks" dst-port=53 \
log=yes log-prefix=";;Drop forward DNS if not local" protocol=udp \
src-address-list=!LAN_NETS
add action=drop chain=input comment="Drop input DNS NOT local networks" \
dst-port=53 log=yes log-prefix=";;Drop input not local DNS" packet-mark="" \
protocol=udp src-address-list=!LAN_NETS
add action=drop chain=forward comment="Drop forward list drop!" log=yes \
log-prefix=";;Drop forward llist" src-address-list=drop_list
add action=drop chain=input comment="Drop input list drop!" log=yes log-prefix=\
";;Drop input list" src-address-list=drop_list
add action=masquerade chain=srcnat out-interface=pppoe-out1
add action=dst-nat chain=dstnat comment="Dest Nat SW" dst-port=8888 \
in-interface=ether1 protocol=tcp to-addresses=192.168.11.2 to-ports=8888
add action=dst-nat chain=dstnat comment="Dest Nat SW SSL" dst-port=8889 \
in-interface=ether1 protocol=tcp to-addresses=192.168.11.2 to-ports=8889
add action=dst-nat chain=dstnat comment="Dest Nat UT TCP" disabled=yes \
dst-port=26333 in-interface=ether1 protocol=tcp to-addresses=192.168.11.2 \
to-ports=26333
add action=dst-nat chain=dstnat comment="Dest Nat UT UDP" disabled=yes \
dst-port=26333 in-interface=ether1 protocol=udp to-addresses=192.168.11.2 \
to-ports=26333
add action=dst-nat chain=dstnat comment="Dest Nat WS File" dst-port=7000 \
in-interface=ether1 protocol=tcp to-addresses=192.168.11.3 to-ports=7000
add action=dst-nat chain=dstnat comment="Dest Nat WS File SSL" dst-port=7001 \
in-interface=ether1 protocol=tcp to-addresses=192.168.11.3 to-ports=7001
add action=dst-nat chain=dstnat comment="Dest Nat WS Nas Admin" dst-port=30001 \
in-interface=ether1 protocol=tcp to-addresses=192.168.11.3 to-ports=3001
add action=dst-nat chain=dstnat comment="Dest Nat 3CX SBC TCP" disabled=yes \
dst-port=5090 in-interface=ether1 protocol=tcp to-addresses=192.168.11.80 \
to-ports=5090
add action=dst-nat chain=dstnat comment="Dest Nat 3CX SBC UDP" disabled=yes \
dst-port=5090 in-interface=ether1 protocol=udp to-addresses=192.168.11.80 \
to-ports=5090
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh port=22
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/London
/system ntp client
set enabled=yes primary-ntp=192.146.137.13 secondary-ntp=185.114.227.160
/system routerboard mode-button
set enabled=no on-event=""
/tool graphing interface
add allow-address=192.168.11.0/24
/tool graphing queue
/tool graphing resource
[admin@MikroTik] >
