DSL Router reboot script
Hi al
Need some assistance / help with running the following script via Mikrotik and setting it to run daily at 6:00am
It is basically to reboot my DSL router.
I use to run it via a linux box, but that machine no longer on the network.
Any help will greatly be appreciated
Thanks in advance
it uses the cURL command.
IP=192.168.1.1
USER=admin
PASSWORD=password
curl --user $USER:$PASSWORD $IP/reboot.cgi >/dev/null 2>&1
for first try something like this :
 /tool fetch url="http://192.168.1.1/reboot.cgi" user=admin password=password
you can ran it via terminal (e.g via winbox), if it work go to system->sheduler and create task with this script
