dst-limit possible problem
I have being developing an advance firewall for an ISP in order to mitigate as much as possible DoS and DDoS attacks. The problem started when I was testing the property dst-limit with value src-and-dst-addresses in firewall filter.
Example: to simulate attack and firewall rule behavior I use KALI to generate the attacks and some firewall rules with action= passthrough just to check the amount of data being processed by the dst-limit rule.
Here are the firewall filter rules:
add action=passthrough chain=forward comment=test in-interface=ether1-wan log-prefix=""
add action=passthrough chain=forward comment=test dst-limit=10,10,src-and-dst-addresses/10s in-interface=ether1-wan log-prefix=""
add action=accept chain=forward comment=test in-interface=ether1-wan log-prefix=""
As you can see the first 4 rules have action=passthrough and the rules 0, 1 and 3 are identical. It means that those three rules must match all the incoming packets.
The issue is that they are NOT matching all packets when:
  1. dst-limit uses src-and-dst-addresses value
  2. The amount of packet per second is high (more than 30.000 packets per second)
  3. Multiple source address attacking one host
KALI command: hping3 -p 81 -2 190.107.176.253 -w 64 -i u10 –rand-source
Otherwise, **if you do the same attack but from only one source this behavior does not occur. **
KALI command: hping3 -p 81 -2 190.107.176.253 -w 64 -i u10 -a 3.3.3.3
Here is a video with the demonstration: https://dl.dropboxusercontent.com/u/3817372/share-public_v2/dst-limit_error.zip
I tested with CHR and x86 with 6.35.4 and 6.36rc40.
Here is the supout.rif: https://dl.dropboxusercontent.com/u/3817372/share-public_v2/supout.rif
Best regards.
First of all, showing your real IP in public forums will be the first thing that will get you DoS DDoS attack :slight_smile:
what is your CPU load on that test?
Hello macgaiver,
Those IP are not real. They are just for LAB test and routed internally.
Regards.
how detect and protect my router from hping?
only allow them at specified rate, drop rest
