Dst-nat 53280 to x.x.x.2 and x.x.x.3 with ros 4 : how?
With old 3.xx (and previous) to forward port 53280 to x.x.x.2 and x.x.x.3 simultaneously, i just used:
Action: dst-nat
To addresses: 192.168.1.2/24
With ros 4.xx is automatically converted to:
To addresses: 192.168.1.2-0.0.0.255
but… dont’work.
How can i achieve the result?
‘To addresses’ should be ‘192.168.1.2’, not ‘192.168.1.2/24’!
Ok…
But, with 3.xx the same port was forwarded from all addresses, with 4 no.
And, again, what means the conversion from “192.168.1.2-254” to “192.168.1.2-0.0.0.254” automatically made by ros 4 in “To addresses” (using winbox)?
Isn’t possible to forward more than one address in the same “rule”?
no?.. works file for me… as far as I can see, nothing was changed between v3 and v4
If i set a single address, works fine, with “192.168.1.2-0.0.0.254” the port isn’t forwarded at all.
I’ve already tried with:
“192.168.1.2-0.0.0.3”
“192.168.1.2-192.168.1.254”
“192.168.1.2-192.168.1.3”
“192.168.1.2-0.0.0.0”
nothing worked!
Only signle addresses are forwarded correctly.
I’m using V4 on Rb112 and 133c.
‘192.168.1.2-192.168.1.3’ automatically changes to ‘192.168.1.2/31’ for me… v4.2, x86
If i try “192.168.1.2/31” my Ros 4 say that “an ipv4 address are expected”…
Also “192.168.1.2-0.0.0.2” dont’work…
maybe ‘mips-le’ architecture is broken…
