DST NAT on 3 Mikrotiks
Greetings
I need to achieve DST Nat to 10.20.1.46 port 8282
Default Gateway 10.20.1.1
Client has Mikrotik RB
10.20.1.1 RB4011 Model
connects to thru PTP Connection to 10.20.0.1 that has Public Interface 24.139.x.x (Public IP)
Do i have to create DST NAT Rules on the 3 Mikrotiks?
What would be the order of Ips on each Rule?
3 Mikrotiks??
You are only showing one??
Basically Destination NAT rule and firewall rule go hand in hand. One needs an allow rule in the forward chain so that all DST rules will work.
“Allow Port Forwarding” connection-nat-state=dstnat
Then you can make as many dst-nat rules as are required.
add action=dst-nat chain=dstnat comment=MyPortFowardRule dst-port=8282
in-interface-list=WAN protocol=tcp to-addresses=10.21.1.46
(assumed protocol TCP as it was not detailed).
If you have multiple MT devices between the server and the internet make a diagram and annotate them with numbers.
For example if there is an MT in between, the only difference is the MT downstreap (its LANIP on the first MT) which is really also its WANIP would be the to-address LOL.
See diagrams will help.
Whether you have to create 3 DST-NAT rules or not largely depends on topology and configuration of your whole network. Ideally create a simple chart showing your different LAN segments and briefly describe what are your goals. It might turn out that your current setup is over complicated …
