dst-nat on block
I have a public /29 block on my WAN interface and I am attempting to dst-nat an address in that block to an internal host. I’ve been successful with src-nat but can’t pass any traffic on dst-nat. I’ve pasted what I think are the relevant lines below.
External Interface: x.x.x.2/29
Dst-nat IP: x.x.x.3/29
Internal Interface: 10.100.100.1
Internal Host: 10.100.100.100
add address=x.x.x.2/29 interface=ether1 network=x.x.x.0
add address=10.100.100.1/24 interface=ether2 network=10.100.100.0
add action=accept chain=forward comment="accept established,related,untracked" connection-state=established,related,untracked
add action=accept chain=forward comment="accept new dst-nat" connection-nat-state=dstnat connection-state=new in-interface=ether1
add action=accept chain=forward comment="accept new src-nat" connection-nat-state=srcnat connection-state=new in-interface=ether2
add action=dst-nat chain=dstnat dst-address=x.x.x.3 in-interface=ether1 to-addresses=10.100.100.100
add action=src-nat chain=srcnat out-interface=ether1 src-address=10.100.100.100 to-addresses=x.x.x.3
add disabled=no dst-address=0.0.0.0/0 gateway=x.x.x.1 routing-table=main suppress-hw-offload=no
I’d appreciate any help
:slight_smile:
What I am thinking is that the x.x.x.3 destination address must be advertised (arp) on the external interface. Once I added x.x.x.3 as a secondary address on the external interface, dst-nat worked.
Correct. It you have non-routed subnet where ISP keeps address from same subnet for its router as your gateway, all addresses must respond to arp requests. So you can either assign them to WAN interface and use NAT, or if you’d want to give them to some internal devices directly, you’d need proxy arp.
