dst-nat / port forward accross VPN locations
I have 2 Mikrotiks at 2 locations doing NAT for each site’s internal network (stock configuration RB750GL, but with the default subnets of 192.168.88.0/24 replaced to 10.1.0.0/24 and 10.2.0.0/24)
Both sites are VPN’ed together and the VPN routing is working fine (tried with both IPsec and SSTP)
Site 1: ether1-wan IP = 1.1.1.1 (example)
ether2-lan = 10.1.0.0/24
Site 2: ether1-wan IP = 2.2.2.2 (example)
ether2-lan = 10.2.0.0/24
I am trying to configure a port forwarding from Site 1 to a web server at Site 2 on 10.2.0.100 port 8080:
/ip firewall nat add chain=dstnat dst-address=1.1.1.1 dst-port=8080 action=dst-nat protocol=tcp to-address=10.2.0.100 to-port=8080
Using Torch on both routers, I see the connection is being successfully forwarded through the VPN to Site 2 and to the web server, however, the src-address remains the public IP address of the remote web browser, so on site 2, traffic is trying to go back out directly through the internet connection at Site 2 back to the user’s browser, instead of going back through the VPN to Site 1 and back onto the internet from there.
I believe I may need to apply routing marks with mangle rules ?
Any suggestions?
You believe right. Mark new connections coming from VPN and then mark routing for reply packets of marked connections, to go back via VPN.
You can also use action=netmap
/ip firewall nat add chain=dstnat dst-address=1.1.1.1/32 protocol=tcp dst-port=8080 action=netmap to-addresses=2.2.2.2 to-ports=80
try this.. and let me know
