I would like to enter to a PC wich is windows that is in a private network which ip address is 192.168.1.187, my first guess was this configuration:
A RB450G which is has in one ether interface 192.168.1.25, and in other interface has 201.x.x.x (public ip address), the default route is
0.0.0.0/0 with gateway 192.168.1.254
When I try to go to from winbox to 201.x.x.x it works, I can enter to the router but I would like to redirect everything to the Windows PC so I created a nat rule
ip firewall nat add chain=dstnat action=dst-nat to-addresses=192.168.1.187
I assumed that when I hit Run and put 201.x.x.x it will redirect inmediately to my windows machine that is 192.168.1.187, but nothing happens…what will be the solution for this problem??
Your IP address list doesn’t show anything on the 192.168.3.0/24 network, yet there’s a directly connected route in the routing table. But it does show an address of 172.16.15.14/24, yet there’s isn’t a directly connected route showing. Your original post doesn’t mention 192.168.3.0/24 at all, it mentions 192.168.1.0/24. And the public IP address doesn’t go to the default gateway of the router.
I don’t understand your topology at all. Can you draw a diagram?
that was what i meant…and it is different because I was making some changes, but the actual network i am trying is the 192.168.3.0 the 1.0 was for taking it as an example
I couldn’t figure out the problem, so I created a pptp tunnel and let the internal traffic pass through the tunnel and that way I can get into the pc in the internal lan at a different place
