I’ve been struggling now for days googling and trying to figure out how to get my dst-nat working so hope someone here can shed some light on what I could possibly be doing wrong.
Ok, the scenario:
I want to access the services running on my pc from the internet, i.e. sabnzb, utorrent, ftp and vnc.
The current setup of my internet is as follows:
PC (172.18.42.97) – RB (PPPoE) – src-nat – Internet
I have managed to setup my dyndns on the rb and all seems to be working on that front. My problem now lies that when I put in the dst-nat to forward the specific ports to my pc ip it just doesn’t work. No packets are even picked up by the nat.
My current dst-nat setting, which someone helped me setup is as follows:
Faced similar problem today. Once again bigear-fatglasses coders changed something radically, without any reason, just for da hell of it. Now dst-nat is not working if dst address is given. removing it - works fine.
Why da %$* do they do that??? I have 4.6 on that RB. Before that I had quite many, since 3. version. Changes like that are NOT in changelog and appeared in DNS, masquerade and now - dst-nat.
Tried all the above suggestions and it’s still not working. That’s what’s bugging me though, everything seems correct but for some reason it will just not work.
Don’t know if it’s the setup I currently use to get inet from my pc or what but something is missing somewhere.
Do I need some sort of forwarding on my pc to return the requests sent to it? Sorry I am pretty clueless when it comes to natting on ROS
Toady, just bear in mind that when you setup that port forward (dst-nat rule) that you won’t be able to test it from within your network, since you haven’t done any NAT Loopback (aka hairpin NAT). You would have to test it from the Internet! Usually we specify an ‘in-interface’ or ‘dst-address’ in the dst-nat rule. If you don’t do that, then you’re going to be redirecting all traffic going to TCP port 80 to your PC.
