i wona to make dst-nat from local address 192.168.0.1:6580 to 66.94.234.13:80
on 192.168.0.1 router i add this:
chain=dstnat dst-address=192.168.0.1 protocol=tcp dst-port=6580
action=dst-nat to-addresses=66.94.234.13 to-ports=80
so, i try to connect on port 6580 on 192.168.0.1 and nothing happen..
in firewall nat i see what packets count, in connection tcp state: syn sent and stop on this…
what is wrong?
You can try just the dstnat example above alone if you want. What I gave is an example of poking a hole in the firewall. With additional ports open, you can put a server on a private IP and have it accessible from the internet.
Add one rule to chain=forward,
'ip firewall filter add action=jump jump-target=hotspot chain=forward',
set for 'guest' user profile,
'ip hotspot user profile set profile_name incoming-filter=1 outgoing-filter=1', that will redirect current profile traffoc to chain=1.
Add rule to chain 1 to drop traffic with specific dst-address,
'ip firewall filter add chain=1 dst-address=172.0.0.0/8 action=drop'.
And I applied this rule at the user ‘guest’
I did that for locking to the user ‘guest’ couldn’t acceed to 172.0.0.0/8 but as you can see I obtain a drop
But now I would need that the user could redirect to the hotspot home page or to nay error page where the user can be alerted that can not be acceed to the rank
How could I do it?
