DST-NAT
I have one public IP address and want to redirect port 3389 to internal IP address 10.10.10.3
The following config does not work:
ip firewall dst-nat add action=nat protocol=tcp dst-address=xx.xx.xx.xx/32:3389 to-dst-address=10.10.10.3 disabled=no
May be I must do something with the firewall because when I scan the public IP with nmap it is “closed”
You should take care that your forward firewall rules also let this traffic through - perhaps it’s blocked at that level?
[admin@BR7] ip firewall> print detail
0 name=“input” policy=accept
1 name=“forward” policy=accept
2 name=“output” policy=accept
What I need to add. Or everything is fine. Where I can fing good info about Mikrotik firewalls
Post the output of “/ip firewall forward print without-paging” - this will show us (and you) if there are any rules in the forward chain that block your dst-natted traffic…
Is there any problem if I have only one real IP address and use it for PAT
the rule should be:
ip firewall dst-nat add action=nat protocol=tcp dst-port=3389 to-dst-address=10.10.10.3 disabled=no
10x a lot. Everything is working
