DST Port over specific WAN
Hi all,
i have the situation that i need to establish connections to a specific port over a specific wan interface (because other host accepts only connections from this wan-interface ip)
Where to start ?
Thanks in advance,
Cheers,
Chris
So .. some progress on this …
i tried https://wiki.mikrotik.com/wiki/Per-Traffic_Load_Balancing
… so far so good. but now the packets get lost somehow ?
i need to reach https://XX.XX.XX.XX:4444 (sophos webadmin) over interface pppoe-dsl1 routing-mark=dsl1
I’ve setup mangle and masquerading according to the howto, but somehow the website is not loading correctly …
i’ve seen the remark
Again using the above as an example lets explain where and why issues can be arise. SSL - The beauty of a website is that are separate requests for different data, ie. loading pictures from 3 different sources would be a request to each respective server. The result is if a we have a website that uses both SSL and HTTP traffic we know that in most cases the website will just answer the request without care of the originating IP address. However, and this is a special case, if the website/program developer checks where the requests are originating and they find that the IP are different, they may not succesfully answer those requests (this can be by design or by accident). I had 2 cases of this, in both cases it was secured medical websites that where using it as a method of protecting their data.
… do you think, that this is the reason for not being able to acces sophos webadmin ?
Thanks in advance
Please post at least your filter / mangle rules and routes. Better would be the whole configuration - otherwise its just guessing.
