DSTNAT doesn't opening port
Hello to all
Newbie in Mikrotik, to make me a little bit the hand, I setup a quick lab where I want to make a LAN base conf (no problem),
a source nat (masquerade) to go out on Internet, and publish a service from Internet to internal.
And now, I’m stuck on destination NAT, probably for a problem of understanding on my part. I made a simple NAT rule:
chain = dstnat
In.Interface.list = WAN (DHCP/ether1)
protocol = 6
Dst.port = 443
action = dstnat
to address = x.x.x.x (IP in the same subnet as the Mikrotik router)
to port = 443
Where I’m a bit confused, and mostly because it doesn’t work, is if you should make a FW (forward) rule or not.
# apr/22/2021 16:40:38 by RouterOS 6.47.8
# software id = S171-9SQD
# model = 2011UAS-2HnD
# serial number = 3F0702E51D4B
/interface wireless
set [ find default-name=wlan1 ] disabled=no mode=ap-bridge ssid=Margotte wireless-protocol=802.11
add name=WAN
add name=LAN
add interface=ether1 list=WAN
add interface=ether2 list=LAN
add address=192.168.60.2/30 interface=ether2 network=192.168.60.0
/ip dhcp-client
add disabled=no interface=ether1
add action=dst-nat chain=dstnat dst-port=443 in-interface-list=WAN log=yes protocol=tcp to-addresses=192.168.60.1 \
    to-ports=443
I guess this point has already been discussed in this forum, but my research gave me a lot of feedback and I didn’t find anything clear for me.
Thanks for your help.
If you had the default set of firewall rules, A MUST for any internet facing device, one of the forward chain rules contains the means to allow port forwarding traffic.
A clearer rule to use in the lab environment would be
add chain=forward action=accept comment=“allow port forwarding” in-interface-list=WAN
connection-state=new connection-nat-state=dstnat
Thank you for your feedback
I followed your instructions, but unfortunately it still doesn’t work. I have tried several scenarios. Without success.
# apr/22/2021 19:01:35 by RouterOS 6.47.8
/interface wireless
add name=WAN
add name=LAN
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add action=accept chain=input comment="Allow ICMP" protocol=icmp
add action=accept chain=forward comment="Allow port forwarding" connection-nat-state=dstnat connection-state=new \
add action=drop chain=input comment="Drop everything that is not LAN" in-interface-list=!LAN
add action=dst-nat chain=dstnat comment="Allow DSTNAT for 192.168.60.1 on the port 443" dst-port=443 \
    in-interface-list=WAN log=yes protocol=tcp to-addresses=192.168.60.1 to-ports=443
add action=dst-nat chain=dstnat comment="Allow DSTNAT for 192.168.100.70 on the port 80" dst-port=80 \
    in-interface-list=WAN protocol=tcp to-addresses=192.168.100.70 to-ports=80
add action=masquerade chain=srcnat comment="Allow SRCNAT traffic to Internet" out-interface-list=WAN
add disabled=yes distance=1 gateway=192.168.111.1
add distance=1 dst-address=192.168.100.0/24 gateway=192.168.60.1
/lcd interface pages
set 0 interfaces=sfp1,ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10
I’m able to ping the interfaces.
I use the Curl to validate that the port openings are functional. The result is the same with port 443.
I have rebooted the router. I did a “/system reset-configuration”.
Everything seems to work except the DSTNAT.
curl -vk http://192.168.111.114
* Rebuilt URL to: http://192.168.111.114/
*   Trying 192.168.111.114...
* TCP_NODELAY set
* Connection failed
* connect to 192.168.111.114 port 80 failed: Operation timed out
* Failed to connect to 192.168.111.114 port 80: Operation timed out
* Closing connection 0
curl: (7) Failed to connect to 192.168.111.114 port 80: Operation timed out
(1) This seems non-standard
TO
add address=192.168.60.1/24 interface=ether2 network=192.168.60.0
(2) where is dhcp server, ip pool, dhcp-server-network ???
The interface is just in /30 (subnetting). I put it in /24, but it doesn’t change anything.
In my lab, I don’t need a DHCP server.
I put the RouterOS v6.48.2 (stable) version too
add address=192.168.60.2/24 interface=ether2 network=192.168.60.0
lab network diagram??
When testing for the ports to be open, are you testing from a device on the WAN side or the server on LAN? Your NAT rule only allows from the WAN. I see no error with your NAT rules. As far Filter rules, the default state (without rules) is to accept. Your original configuration was not block the NAT.
If you was testing from WAN, I would suggest the issue is with the configuration of the server. A firewall on the server or an IP configuration error. You should move that ether to a bridge and add a second port to connect a device to test to it’s LAN IP.
Here it is, I hope it will be clearer
Well you have the cisco router in between so does that forward the port to the WANIP of the MIkrotik ROuter (the LANIP on the cisco private subnet).
curl test from 192.168.60.0/24 or /30 network works?
